Author Topic: Itb's  (Read 15888 times)
Itb's
« on: December 01, 2013, 06:39:12 PM »
Would I be stupid to think a box stock b18c5 on a p28 in chipped ecu that runs and drives "fine" would still run after a set of 48mm jenvey itb's were installed with the stock injectors or is that too much to ask?
Re: Itb's
« Reply #1 on: December 01, 2013, 07:01:20 PM »
Yeah you would have to Alpha-N base tuning
P28 w/ a ITB tune would work but not on a stock ITR tune.  :noel:
I know Crome, EcTune, Neptune have ways of ITBs.
I know Crome should be able handle this, maybe shine a CRX cut out in the sky and Leed to come up and help.  :noel:
Re: Itb's
« Reply #2 on: December 01, 2013, 07:52:44 PM »
The real question is, why would you bother? Is this for your HT build?
Re: Itb's
« Reply #3 on: December 01, 2013, 07:53:36 PM »
I thought Chad was building a OG mini?  :noel:
Re: Itb's
« Reply #4 on: December 01, 2013, 08:15:34 PM »
One time in a pinch I ran a b20V on Crome without alpha-n tuning. I was amazed at how well it ran.
Re: Itb's
« Reply #5 on: December 01, 2013, 09:39:19 PM »
Ding!
Was hoping it would at least run/move under its own power until I can get it tuned.
Re: Itb's
« Reply #6 on: December 01, 2013, 10:12:56 PM »
Ding!
If you build a vac manifold and plumb your MAP sensor off of it, it should run well enough to move around.
Re: Itb's
« Reply #7 on: December 01, 2013, 10:25:29 PM »
Supposed to say non chipped p28
Re: Itb's
« Reply #8 on: December 01, 2013, 11:35:17 PM »
If the map sensor gets a signal from all cylinders, I wouldn't be surprised if it would move under its own power, but I doubt you would really drive it anywhere
« Last Edit: December 02, 2013, 01:44:01 PM by PhilStubbs »
Re: Itb's
« Reply #9 on: December 02, 2013, 01:20:19 AM »
You think someone could do a basemap to get it better?
Re: Itb's
« Reply #10 on: December 02, 2013, 11:36:06 AM »
If memory serves me right the stock ecu will run with itbs it will just be rich down low decent in the middle and lean up top either way i would think it would move around.
Re: Itb's
« Reply #11 on: December 02, 2013, 01:44:18 PM »
I edited my post. Autocorrect fail
