Author Topic: Mfactory LSD K20 problem...  (Read 51559 times)
walter
« on: April 11, 2014, 06:14:48 PM »
Hi there! im installing a MFactory to a K20Z Civic 06+ tranny, installed new bearings and when i going "sit" LSD it touch with countershaft bearing.. what's wrong with that? Bearings are Koyo 6208CM GSR that came with Mfactory LSD.
Maybe i need any shims? or pull off a bit top bearing?  ???
Re: Mfactory LSD K20 problem...
« Reply #1 on: April 11, 2014, 09:35:53 PM »
Does it use roller bearings?  I've never seen inside a K series tranny before so IDK...
If it used roller bearings maybe they are pressed on too far?
DraginX
« Reply #2 on: April 12, 2014, 03:00:23 PM »
Looks like it needs to be shimmed.
walter
« Reply #3 on: April 12, 2014, 06:54:42 PM »
Hi, what's the clearance for tranny?
« Reply #4 on: April 12, 2014, 07:14:06 PM »
Like tranny suprize?   :?:
walter
« Reply #5 on: April 12, 2014, 07:30:09 PM »
i meant transmission lol..ive seen gap is about 0.10mm.. i'd have to get 3-4 shims  :-\
t3_60trim
  • Lurker and window peeper
  • N00B *Read Intro Sticky*
« Reply #6 on: April 12, 2014, 08:32:35 PM »
Waiting for "Chuck`s" enigmatic one word answer to your problem.  Thought the expert would have chimed in by now.
Do you have the correct differential bearings on this LSD? If I am right the shim isn`t on that side of the case anyway which makes me think you have the wrong diff bearings on there.
« Reply #7 on: April 12, 2014, 10:10:09 PM »
Who are you and where is your intro post?
« Reply #8 on: April 14, 2014, 05:58:51 PM »
.001 to .010 "   is what you want for the shims. Shim should be on pass side pop seal off a d measure. You can't put the bearings on too far... only not far enough... your install is fucked up somehow.
« Reply #9 on: April 14, 2014, 06:08:22 PM »
I don't know shit about k series, but you said you're using GSR bearings?
Are those supposed to be interchangeable with a k?
I know b16/ls bearings are a different width then gsr bearings (the inside race at least).  Fucks alot of people up in the B series world.
walter
« Reply #10 on: April 14, 2014, 08:39:18 PM »
problem was final drive upside down!
B16 bearing are the same as K20 series.
« Reply #11 on: April 15, 2014, 12:43:54 AM »
Lol!
« Reply #12 on: April 15, 2014, 01:23:40 PM »
Jesus christ who built it
« Reply #13 on: April 15, 2014, 05:04:28 PM »
he did.
first post he said he is trying to install the diff but it didn't fit right.
shit happens and the ring was upside down.
« Reply #14 on: April 15, 2014, 05:56:18 PM »
I've done worse  ;)
« Reply #15 on: April 28, 2014, 08:10:59 PM »
Large bearing D series/B16/LS/K all use same diff bearings.
My first K....not allowed to show the LSD used....one of one in the USA....NOT MFactory....
Other than needing a press for the shafts (I got by without one) and having to cut the diff bearing apart to get speedo ring gear off, it was easy.
New 1-R-2 sleeve along with carbon synchro for second....
