Author Topic: Catalytic converter and turbo.  (Read 21033 times)
rudebwoy
« on: May 09, 2009, 09:52:04 AM »
ITS A NO GO!
race track opened in Germany may first this year, so got car ready, and roll out to the to see what I will run 8 psi , note I have 11.5 psi spring in my wastegate, and boost controller set to 14psi, something is wrong, I double check my s300 boost setting. all seemed fine, second run the following day with slicks, yes I am gonna do some damage, cause you can't beat me a 20 psi ;D. boost set for 20 psi came out the hole like a bore out of hell O0. 16psi on the 2step. 3rd gear I had no power one the race, but only at 4 psi after checking data log. I raced 3 more times before I quit.
drove my car home on the autobahn about 150 mph the whole way on 4 psi.
a week a of trouble shooting and and checking piping swapping wastegate springs, changing couplers and piping.
bypassing boost cantroller and all.
note car still drives good so I had no signs of a blocked cat.
last check after doing some thinking. normally I can hear the turbo through the exhaust at idle or low speeds. did not hear it. so I decided to check the cat , when I pulled it half the internals were already gone, the rest was just blocking the exhaust flow, punch the rest out :somb: and reinstalled, problem fixed instantly.
this happened to my friend last year except it did not block his exhaust it got blown out on its own.
magnalow high flow
Re: Catalytic converter and turbo.
« Reply #1 on: May 09, 2009, 10:30:45 AM »
ok
« Reply #2 on: May 09, 2009, 12:34:16 PM »
well better keep an eye on things, we took the cats out of my buddys 450ish hp car and it leaned out a full point and then ruined a piston the next day at the track.
« Reply #3 on: May 09, 2009, 12:36:12 PM »
congrats on the retune after making a major modification
« Reply #4 on: May 09, 2009, 12:37:43 PM »
cats and rich tunes to keep detonation at bay do not play well together, the cat gets way to hot trying to burn off the excess fuel and melts down.
« Reply #5 on: May 09, 2009, 12:38:46 PM »
wasnt my car, he knew it was a problem but the tuner said it should be ok. built motors should be able to handle 12.5 afrs.
« Reply #6 on: May 09, 2009, 12:39:42 PM »
how many psi?
« Reply #7 on: May 09, 2009, 12:43:19 PM »
whats it matter. it was mid 400 hp car. 16ish i think
« Reply #8 on: May 09, 2009, 01:40:33 PM »
how many psi?
Psi is meaning less unless the turbo is known, psi brakes nothing cfm's do.
« Reply #9 on: May 09, 2009, 02:16:09 PM »
how many psi?
he told me the conclusion i was going to make
rudebwoy
« Reply #10 on: May 09, 2009, 04:08:27 PM »
I definatley had to retune the car . I had add a lot more fuel to the entire map, went from 14.7 afr idle to 18 afr. and cruising around 16.4 afr, boost was at 12.7 afr after I removed the cat insides.
magik123
« Reply #11 on: May 09, 2009, 04:30:54 PM »
same happend to me on the dyno.. made 130hp WTF ??? pulled the cat made 180  :noel:  everything was caught in the bend over the rear suspension.
« Reply #12 on: May 12, 2009, 11:38:57 AM »
orly? How about bearings, did you modify the block for some speacial bearings too? Detonation may not kill a piston, but it will break stock sleeves, ruin valves, and destroy bearings.
When I pulled my EF's cat out, half the shit inside was melted. Cats are definately not intended for power or too much fuel. I laugh at the high-flow waste-of-money crap.
« Reply #13 on: May 12, 2009, 02:10:39 PM »
So wait hold on!  You run a cat?  Thats the first thing I take out when I start to try and make a car fast...   Plus people buy them....
« Reply #14 on: May 12, 2009, 06:18:19 PM »
I cant belive that he was even running one. ???
I dont know anyone that has a honda that makes over 200 hp and still has a cat. Why would you not take it out? SHould make for alot faster spool, and alot more top end power.
rudebwoy
« Reply #15 on: May 13, 2009, 01:40:53 AM »
I had it in because I recently had instection, plus it makes my car more quiet, I have 3" exhaust with know muffler, I think what really got it melted was the 2step at 6500rpm 16psi lauches, I tested it 2 times before I lined up and once on the line. plus I drove for 4 months on it. the cats are not that bad unless you abuse the shit out the car, normal driving is ok.
« Reply #16 on: May 13, 2009, 12:19:18 PM »
SHit, I drive my car like I stole it!!!!!  :yes:
