Pages: [1] 2 3   Go Down
Author Topic: **updated goodbye 93 ej2** hello 98 dc4 build teresa! !  (Read 66550 times)
darkess90
  • McNoob who has not posted a proper intro yet.
« on: July 03, 2014, 05:02:08 AM »
Sup rhmt!, building my rusty dd I bought this yr in February i got for cheap. It's a 93 Aztec green ej2 or civic coupe dx, 203k automatic. Any who start this build great with more pics then my friend crxvtec91 ooooh :P,with my idiot cousin in the pics as well hahaha. I just don't know why the fuck my porn pics are coming out small?!
Yes I thought about n/a Mike :)
as you see her is how I bought her so don't fuckin assume it was me that put put that duct tape lol :-X. Oh that rust  :'(
nowon to de-ricing her I got these oem stanley corners an headlights with a broken tab so hello lil pink rope till I find another passenger side headlight
She is fuckin 4x4 for now lol
My goal is convert to manual and for now close to 350whp ls turbo or b16 stock internals  :noel:. I will take thr coupe to body shop after I do the swap. Fuckin cousin lol he knows what's up an why I'm snapping a pic :noel:
« Last Edit: August 19, 2014, 12:33:38 PM by darkess90 »
Insanity=fun ;)
darkess90
Re: 93 ej2 civic turbo build aka Madison
« Reply #1 on: July 03, 2014, 06:07:53 AM »
So I got this cheap Ls engine from a local friend of mine that I trust an believe him it's good cause if it starts up an is bad he gives me back my money or gives me another engine so warranty lmao 8)
 intake manifold an stuff is off cause took it to get ported thanks to a great friend of mine that is a OG ;). Yes I have the integra throttle cable I need.
one to more parts. New timing belt, tensioner, shift linkage pin an clip,  not in the pic water pump from advance auto :P
Spoon rep paint able side mirrors non power
Gsr shift linkage with stock daul bend I got cheap in NJ
Holset hx35 8 blade I paid $250 for off a 97 dodge 5.9L cummins
Stock flywheel I drove 2 hrs for I love driving an traveling just ask Steven lol,  yes it's getting resurfaced.
 They forgot 2 bag that 8mm nut haha
*$52 in just bolts an nuts from acura automotiveparts.org good bye budget build  :-\.
Upper an lower alternator bolts an nuts also the 5 bolts that connect the trans 2 the block which the part number for those bolts is look under ENGINE WIRE HARNESS-CLAMP (2)
23-90050-PG7-000 BOLT, FLANGE (12X65) qty 2
24-90051-PE0-000 BOLT, FLANGE (12X70) qty 3
(Looked up under 01 integra type R)
I was going to just get the bolts from fastenal cause I know the thread pitch 12mm x 1.25 x 70 with 17mm head but prices weren't that far apart.
emusa fmic 25x12x3
Got a digital clock an new hazard button at my local junkyard for $4 cause Madison's faded like my cousin be most of the times lol
ah how simple things make a big difference ;DDD
drove 2 hrs for this good clean cheap S80 Ls trans an manual dc4 t bracket off a dude parting out his running DC4 in Philly. I was going to get a b16 trans then put a ls FD 4 the highways an mpg but I'm like screw it ls is ok enough an if I want it a lil closer the gears I'll install a 4.7 FD
Twin scroll t4 topmount with 44mm v-band flanges
Passwordjdm purple rad stay. Her theme in the engine bay will be joker/hulk: purple, green, black hopefully
« Last Edit: July 03, 2014, 10:25:48 AM by darkess90 »
Insanity=fun ;)
darkess90
« Reply #2 on: July 03, 2014, 06:32:54 AM »
Got this non power rack and pinion that just needs new outter tie rods from my uncle(which it comes off the vx or cx civic hatchback? Not sure)
Got a slamming deal on a oem optional matching color of my interior armrest, manual cluster and td-55u or obd1 ls distributor for $63!!.
Dizzy needs a new cap
Got this clean bracket off a red ej1 that goes under my driver side quarter panel tail light cause Madison's is bent an rusted.
Trying to make Madison a sleeper so I painted my fmic black my friend that was going to build a g23 painted it fo me cause I can't spray paint for shit but I tried though :P
Man at least her frontend is clean compared to her body ::)
« Last Edit: July 03, 2014, 10:20:34 AM by darkess90 »
Insanity=fun ;)
darkess90
« Reply #3 on: July 03, 2014, 06:47:44 AM »
Got this clean extra obd2 ls vc for like $10 while the other I got get it tapped for the -10 an bungs
Insanity=fun ;)
« Reply #4 on: July 03, 2014, 08:33:48 AM »
Check out fixmyrust.com!
« Reply #5 on: July 03, 2014, 09:09:55 AM »
Good  start keep the updates movin'
And Do work!!!!!!!   :noel: :noel: :noel: :noel:
darkess90
« Reply #6 on: July 03, 2014, 10:22:48 AM »
Okay I will bro but just came from my local body shop to cut an weld my quarter panels,  fix bith dented up doors, paint my new driver side fender, rear bumper and matching color Aztec green $1300 el Diablo!!! :o lmao
« Last Edit: July 03, 2014, 11:10:12 AM by darkess90 »
Insanity=fun ;)
darkess90
« Reply #7 on: July 03, 2014, 10:24:31 AM »
thanks dude!! I will had her in a build thread in annoying honda-tech which have mad mother f-ing haters an biters lol so I have pics an video
Insanity=fun ;)
darkess90
« Reply #8 on: July 03, 2014, 10:44:58 AM »
So this past winter was so fierce that I snapped her original door handle from forcing it open when it was frozen at 7am lol. So I got a free one at my local jy.
Got a obd1 manual integra engine harness uncut
New bolts an washer from honda for the t bracket that bolts up to the block $21
Manual halfshaft cause can not use almost anything auto
Good clean halfshaft bolts I ordered used
Got the post mount I needed to swap the b18 in cause mine was missing a stud idk ??? With hardware
Clutch pedal, master cylinder with reservoir in good condition I got from the junkyard yard for $23 with manual brake pedal off a junked ej1
So I took the bracket that bolts/holds the reservoir to the shock tower to my local machine shop 2 get sandblasted cause it was going to be a eye sore
fucking A man >:( she is overheating like crazy an I thought it was the fan switch that was bad so I bought it $30 unnecessary investments man I found the problem
Watch "Rmht Madison ej2 93 eg overheating prob found" on YouTube
Rmht Madison ej2 93 eg overheating prob found: http://youtu.be/ut5drgCCSf8
so hello yonaka aluminum radiator with shroud an 12" fan I had to buy it anyways when im boosted but dam not now lol oh well fuck it.
« Last Edit: July 03, 2014, 10:48:15 AM by darkess90 »
Insanity=fun ;)
darkess90
« Reply #9 on: July 03, 2014, 10:58:36 AM »
 :D Yonaka rad arrived yes I know it's for a manual trans
$170 shipped to my door hell yeah and my innovative 3-bolt 75A mounts arrived with the AT to MT mount as you see in the far left
Change is near folks  O0
« Last Edit: July 03, 2014, 11:27:44 AM by darkess90 »
Insanity=fun ;)
darkess90
« Reply #10 on: July 03, 2014, 11:09:04 AM »
So I really don't like it when ppl do this but I did it mostly out of curiosity an wanted to do it just once besides her ex lip that came with her is broken an doing this till I order a new one from honda so it's temporary. I stickered bombed it remember she is going to be my superwoman basically lmao!.
Insanity=fun ;)
darkess90
« Reply #11 on: July 03, 2014, 11:24:23 AM »
So I got these ok leather rsx type s or DC5 seats( yes I know the rear dc5 seats don't fit 93-95 coupes) for $60 at my local jy front an rear I can take them to my local auto upholstery an he's charging me cheap to fix the passenger an rear but I'ma sell them cause then she wouldn't be a sleeper even if their oem seats from acura but ppl that don't know they are will think their racing seats or ppl that know think I have a beast under her hood ;).
So I ended up selling them an made a profit of a whopping $200 8) a dude drove 2 hrs from jersey city, nj to buy them cause they go for more then that but im good with $200 in my pocket lol an wanted a quick sell obviously. Right Steven buddy.
« Last Edit: July 03, 2014, 11:29:04 AM by darkess90 »
Insanity=fun ;)
« Reply #12 on: July 03, 2014, 11:53:52 AM »
Looks solid besides the lip.
darkess90
« Reply #13 on: July 03, 2014, 12:39:59 PM »
thanks dude :) and like I said before that wrapped lip is just temporary I don't like it much but my  lil cousins an baby niece does so I mostly did it for them those lil buggers.
Insanity=fun ;)
« Reply #14 on: July 04, 2014, 11:17:39 AM »
Good build so far. Except for maybe the manifold, it's a cheap but not ghetto build. Good choice on a shrouded radiator.
darkess90
« Reply #15 on: July 05, 2014, 10:01:48 AM »
Oh wow im getting compliments from you!? :o thanks dude. I got to tell steven this inperson lol. ;DDD. Yeah I was going to send you the money through paypal dude for your injectors but my friend ended up selling me his 560cc pink tops off his evo 8 for $80! That I need to buy new o-rings.
just needs new o-rings
« Last Edit: July 05, 2014, 05:22:32 PM by darkess90 »
Insanity=fun ;)
« Reply #16 on: July 05, 2014, 03:43:33 PM »
Rad little build you got going.  Id go bigger with the injectors.  Sell those fuckers on CL and pick up some HiProfile Injector-Nation.com IN900's and ball outa control on a budget.
« Reply #17 on: July 05, 2014, 04:24:51 PM »
X2 if you make the same power as pops you will be close to maxing it out the injectors.
darkess90
« Reply #18 on: July 05, 2014, 06:03:40 PM »
thanks dude :) and true yo Hi profile ima PM you.
Shit, they on CL and fb now for sale with some other parts I got bro lol!. True pops told me in the first place to get injectors from hiprofile.  :P
Insanity=fun ;)
darkess90
« Reply #19 on: July 06, 2014, 12:47:16 PM »
Nah guys I'm good with those injectors all I want is 350-380whp area!. Besides a good friend of mine did 400 in his ek with evo injectors. ;DDD.
Insanity=fun ;)
boosted 00 black si
« Reply #20 on: July 06, 2014, 01:29:57 PM »
Made 385 on evo560's on my boosted b16  8) u will be ok kev
http://www.realhomemadeturbo.com/forum/index.php/topic,4084.msg59013.html#msg59013
« Last Edit: July 06, 2014, 01:33:31 PM by boosted 00 black si »
go fuck your self
BORN TO BOOST
LITTLE B16.400whp on 16psi
darkess90
« Reply #21 on: July 07, 2014, 12:40:54 AM »
Thanks bro :noel: I believe you of course!  :). But when I want more boost Hiprofile an i are going to have some business feel me lol. I fuckin snapped the old cotter pins cause they were pissing me the fuck off in my local jy an I got the right size Cotter pin I needed at lowes cause I have no home depot closest one is 28 miles away.
. My fucked up finger still can't bend hello finger splint :-\
Insanity=fun ;)
darkess90
« Reply #22 on: July 08, 2014, 04:20:29 PM »
So I installed the manual brake pedal an clutch pedal with master cylinder an I wanted to express what this is an what it does also what you should do when going manual basically cut it get rid of it,shot the fuckin thing, toss it away idk Lol.
This is the interlock control is the box that makes the key not come out of the ignition when an auto car is in neutral so I can leave Madison in neutral like other manual cars. Also if you unplug that interlock control now in a auto car it wont let the shifter get out of park just to let you guys know( I tried it already ::) the hell ) lmao.
dam piece of shit  >:( auto brake pedal^ didn't want to come out so easy!!, you know how uncomfortable position you have to put your body in to do this job?, man...with a messed up index finger I can't use yet hahaha :P
Yeah going to get a oem rubber cover for the clutch pedal it must have fell off when I was putting it in Madison's trunk ???.
Insanity=fun ;)
« Reply #23 on: July 09, 2014, 11:20:40 AM »
Sand the metal and put some grip tape on it, the kind used outside.
darkess90
« Reply #24 on: July 11, 2014, 04:41:50 AM »
 ??? What for the clutch pedal? Which if so killer idea dude!. Hey ratcity I seen you sold your garrett turbo in honda-tech marketplace very nice yo :P.
« Last Edit: July 11, 2014, 08:06:07 AM by darkess90 »
Insanity=fun ;)
darkess90
« Reply #25 on: July 12, 2014, 12:19:17 PM »
Got my $10 stock flywheel resurfaced at my local machine shop ;DDD for $47
my -4 an oil feed line kit arrived from ebay ;) thank you pops saved me $150 from piecing it out at summit racing.com
Insanity=fun ;)
« Reply #26 on: July 12, 2014, 01:10:45 PM »
Only downside of the sand paper pedals is, they will fuck your shoes up.  So if you are a baller ass mother fucker who wears nice shoes to show off to the bitches, think again playa playa.
darkess90
« Reply #27 on: July 12, 2014, 04:28:59 PM »
 ;DDD I kinda do wear nice shoes but fucking hilarious dude lmao I can't stop laughing when I read that but im good I got a oem ok brake pedal cover for the clutch pedal in the jy. 8)
Insanity=fun ;)
« Reply #28 on: July 12, 2014, 05:50:24 PM »
Haha well yeah, they will get beat up pretty good unless you are careful and they wear out from the sand paper but I'd say its worth it.
« Reply #29 on: July 12, 2014, 11:20:50 PM »
Do you guys molest the pedal with your shoes or have tiny feet? Mine aren't huge and they're still too big to pivot/slide, I can only push like I'm pressing a tee into the grass.
Pages: [1] 2 3   Go Up
