Author Topic: Discovered something interesting working on a boost controller issue  (Read 11115 times)
DSharp
I've been having some issues with my car hitting boost cut (22psi) in 3rd.  I checked the waste gate and the lines and everything looks fine.  My laptops been down for a couple months, so I cant see whats going on in the ecu.  I decided to hook up a needle valve between the top of the waste gate and the mac valve to bleed a little pressure off (with a t fitting and about 7-8 feet of line, so I can adjust as I drive).
First pull, it worked, it now only hit 11 psi.  Then I started to close the valve to raise the boost to my target... 18psi.  The funny thing is that it never got there it only got to 14psi, even when the valve was completely closed.
I figured I had a leak in the connection or the valve, so I folded the line over on itself to seal it and added a ziptie.  While doing this, I effectively shortened the line to about 5 feet.  Now it was hitting around 16 psi.  Now I'm wondering why its not hitting the boost cut, so I shorten the line to about 3 feet and seal it.  What do ya know? 18 psi!
My thought is that changing the volume of pressurized air connected to the top of the waste gate changes the pressure achieved at a given duty cycle. It seems that I always have to adjust my duty cycle across the board from winter to summer, maybe just changing the "pinch point" in this line will be a simpler solution?
I still don't know why I had the problem in the first place though, maybe the mac valve is clogged or shitting itself?  I don't really care right now, I just wanna hit the track on full boost.
DSharp
Re: Discovered something interesting working on a boost controller issue
« Reply #1 on: September 18, 2014, 10:21:41 PM »
opened the boost controller up, it was dirty as fuck.  sprayed some carb cleaner in there and it quit working, i was getting wastegate pressure.  took it all the way apart, soaked it in carb cleaner, got more dirt and shit outta it, then soaked it in oil.  now its about 3 psi over wastegate.
timing is shitty cause im supposed to go to darlington tomorrow and run it.
2JZfreak
« Reply #2 on: January 01, 2015, 05:54:33 AM »
good info, this i like reading.  :noel:
