Author Topic: tuning winter blend vs summer blend fuels  (Read 12268 times)
shanerv
« on: December 28, 2014, 07:39:52 PM »
so figured I would ask if you live in the northern regions if you have had issues or notice differences when tuning turbo cars with summer blend vs the winter blend of gasoline's
Re: tuning winter blend vs summer blend fuels
« Reply #1 on: December 28, 2014, 11:00:05 PM »
Didn't know there was winter gasoline. Winter diesel yes but didn't know about gas.
« Reply #2 on: December 29, 2014, 05:21:07 PM »
I'm using Petrocanada 94 in the winter for the Teg and haven't notice a difference really. I know there's additive in the 94 but it works well for me.
The motor is a b16b (10.8:1) @8psi and no problem so far. Winter or summer.
I also didn't know there was a winter blend. That's a fact or you think there's a blend?
shanerv
« Reply #4 on: December 29, 2014, 09:08:49 PM »
i have heard that it affects afr a bit but I was wondering about hp affect it might have
« Reply #5 on: December 30, 2014, 01:52:40 AM »
w/ E10 AFR should be 14.09:1
10% ethanol blended gasoline is 14.09 AFR.  E10 gasolines will be stoich at 14.09-14.7 AFR.
Using a display calibrated for gasoline, 12:1 on gasoline, 11.5:1 on E85 (stiffer alcohol blends) and you will be fine.
http://www.realhomemadeturbo.com/forum/index.php/topic,22633.msg225979/topicseen.html#msg225979
Keep in mind if you use a AFR displayed in lambda 1.0 is stoch. for any fuel used.  :noel:
