Author Topic: a few questions about axles and mounts b18b1 into ed  (Read 47891 times)
shoeboxbeater
« on: January 03, 2015, 12:31:36 AM »
I bought myself a 91 DX automatic and an obd1 b18b1 with hydro trans that the sticker that I can't read. This swap I bought was in an eg. My questions are will the axles and int shaft that were used in the eg b swap work with my ed with this hydro transmission or do I have to use? also my friend Has b series mounts for the b18a1 with cable transmission. Can i use b18a1 mounts with the post mounts for the b18b1 with the hydro trans? Is there a difference between the automatic and manual mount that is welded onto the unibody?        I have searched dseries.org here h-t and others.  I looked in the FAQ and I did not see an answer to my questions. BTW who ever ruined the original site is a fucking asshole there was so much useful information that has been lost. Looks like many documented builds have been lost. Thanks.    Also will the eg b series shift linkage ( the stabilizer and torque bars) fit on my ed shifter and trans?
Re: a few questions about axles and mounts b18b1 into ed
« Reply #1 on: January 03, 2015, 01:35:33 AM »
You need a newb intro post, Follow these rules http://www.realhomemadeturbo.com/forum/index.php/topic,25.0.html
Then I will tell you the answers. I know all of the answers but 1 and I know someone else here know that one.
shoeboxbeater
« Reply #2 on: January 03, 2015, 04:30:42 AM »
I had my newb  intro post ten years ago. My apologies. I'll up load more from my laptop in the am. The only porn you get is of hotrex's herpes. Can I post links that show in the IMG brackets from any site? Can't attach photos?  And what is with neodouche ruining this site what a fag. I read the 14 page post of the drama. This site made his business.
« Reply #3 on: January 03, 2015, 11:02:50 AM »
That was the old site we years ago. About 5 years ago jeff sold the site to Chris harris, (xenocron) after about a year of running the site he no longer wanted it and sold it. Everything went to hell. So the members that actually cared about hmt left and started Real hmt. Jeff stepped back in and took ownership or rhmt for a little while. So the newb post for here is required just like the old site, but more graphic and less rules once newb post has been done. Yes you can use IMG brackets. No you can't upload directly to the site. And the neodouche running g this site is a stand up guy from hmt.
shoeboxbeater
« Reply #4 on: January 03, 2015, 12:49:00 PM »
« Reply #5 on: January 03, 2015, 12:56:45 PM »
Cannot post facebook picts here, facebook has some restrictions.  :noel:
shoeboxbeater
« Reply #6 on: January 03, 2015, 05:38:49 PM »
shoeboxbeater
« Reply #7 on: January 03, 2015, 05:51:42 PM »
I bought this pile of shit for 900. It was in Florida for most of its life. Previous owner pulled all of the interior out  to put in new carpet that is  pre-molded. I test drove this sitting on a milk crate. This thing gets 20 mpg as it sits and burns a little oil. So 2 days ago I bought the ls swap for 600 to drop in. I bought a pedal cluster for 20. It needs rear shocks and rta bushings. Do the da shocks fit on my springs? I'd like to spend all kinds of loot but I have a child and need to make this thing a little more enjoyable and safe. My ultimate goal is to go turbo of course.
shoeboxbeater
« Reply #8 on: January 03, 2015, 06:07:42 PM »
And for you mr rex here is the other half of my noob post
http://ts1.explicit.bing.net/th?&id=HN.608010143660900650&w=300&h=300&c=0&pid=1.9&rs=0&p=0[/img]
« Reply #9 on: January 03, 2015, 09:26:32 PM »
Fucking quality.
will the axles and int shaft that were used in the eg b swap work with my ed with this hydro transmission?
YES
can i use b18a1 mounts with the post mounts for the b18b1 with the hydro trans?
YOU WILL HAVE TO USE B18A1 MOUNT ON THE DRIVERS SIDE (POST AND MOUNT) THE REAR T BRACKET/MOUNT WILL HAVE TO BE FROM A DA INTEGRA AND THE BODY MOUNT WILL HAVE TO BE FROM A MANUAL CAR. AS FAR AS THE TRANSMISSION MOUNT YOU WILL NEED TO BUY THE ADAPTER MOUNT OR MAKE A MOUNT.
 Is there a difference between the automatic and manual mount that is welded onto the unibody? YES
YOU WILL NEED TO CUT DOWN THE LENGTH BUT IT WILL FIT ON YOUR TRANSMISSION AND SHIFTER
Also here is this
http://honda-tech.com/honda-crx-ef-civic-1988-1991-3/detailed-b-series-into-crx-ef-civic-parts-list-more-2769325/
« Last Edit: January 03, 2015, 09:28:09 PM by ratcityrex »
shoeboxbeater
« Reply #10 on: January 07, 2015, 04:05:17 AM »
Where is the automatic specific mount? I bought the  inovative kit with the actuator and mounts for hydro bseries from swapshop racing. The guy there told me I just use the kit plus post mount and rear t bracket from the DA.
« Reply #11 on: January 07, 2015, 12:24:41 PM »
iirc the body mount on the transmission side/pass side is different from auto to manual.  But I could be wrong. Maybe it's just the transmission side that is different.
shoeboxbeater
« Reply #12 on: January 07, 2015, 02:27:28 PM »
I also read somewhere that this may have been the case but swapshop racing told me they have done this swap with stated brackets. My parts pile is getting bigger. I ordered a obd0 to obd1 jumper harness and a 4 wire o2 sensor today.
« Reply #13 on: January 08, 2015, 08:54:37 PM »
make one this is rhmt I did and the innovate hydro kit is a fucking joke my/dustin kit way better
« Reply #14 on: January 13, 2015, 12:06:07 AM »
Gingers are right up Russ' alley.  Thanks for redeeming yourself faggot
« Reply #15 on: January 13, 2015, 02:46:42 PM »
Yes.... yes they are  :noel: :noel: :noel:
shoeboxbeater
« Reply #16 on: January 15, 2015, 03:43:08 PM »
If I had access to a Bridgeport or a Taiwanese knock off I would make my own mounts. Let's see dustins home made mounts.
shoeboxbeater
« Reply #17 on: January 16, 2015, 04:31:41 PM »
Where are the pics? If you are a real og you would be cutting and threading yourheadsheadstuds and other various bolts.
« Reply #18 on: January 16, 2015, 07:00:26 PM »
Who is this directed towards?
shoeboxbeater
« Reply #19 on: January 17, 2015, 12:56:19 AM »
directed towards this comment.
« Reply #20 on: January 19, 2015, 02:19:09 AM »
Oh talkin to me. first if you need a mill to make mounts your a bitch steel, grinder, drill and welder. Whats the shit about tappin threading head bolts?
there ya do work
« Reply #21 on: April 19, 2015, 02:17:40 PM »
Get used cable hasport mounts if you can.  Worst case innovate.  The ebay ones are total shit.  Engine placement and axle angle is garbage.
LS cable tranny 91-92. no 90-91 ls trans.
DA axles. DA clutch cable or modifiy B series cable mount.
