Author Topic: Which turbo next?  (Read 17536 times)
Which turbo next?
« on: February 05, 2015, 04:38:47 PM »
So im in the progress of getting the crx ready for this session. At the same time im thinking about next year.
The Hx-35 7 blade is just about max out. I been looking at the BW s366, looking at both compressor maps I feel the s366 will spool about the same while making a TON more power.
Thoughts?
Re: Which turbo next?
« Reply #1 on: February 05, 2015, 05:30:13 PM »
Thoughts?
Saw this on Facebook, I'd say go for it $599 and good 600whp+ and reliability.
« Reply #2 on: February 05, 2015, 05:48:12 PM »
New turbo gonna be on for the NC meet this year?
« Reply #3 on: February 05, 2015, 06:31:26 PM »
I have run them both, it will spool about the same, but will light quite a bit later. It will also give you a lot more potential.
« Reply #4 on: February 06, 2015, 09:55:35 AM »
Thoughts?
I can get it for $550 maybe $500.
This turbo is more for next year. Want to run the current setup and see what kind of numbers it will run.
Great, that is what I wanted to hear. Next more will have more compression so it should help. Thinking of going with either 10 flat or 11 flat comp.
« Reply #5 on: February 06, 2015, 06:10:38 PM »
Thoughts?
Did you ever get it where you could spray it on top of the boost?
« Reply #6 on: February 07, 2015, 07:31:52 PM »
Thoughts?
Yes right before the clutch gave out on the dyno :P
« Reply #7 on: February 07, 2015, 07:58:47 PM »
Thoughts?
New clutch since then?
If so, vids of boost and spray!
« Reply #8 on: February 07, 2015, 09:23:42 PM »
Thoughts?
Comp twin disc also have a small mountain of new parts that has yet to make its way onto the car.
« Reply #9 on: March 01, 2015, 03:10:16 PM »
Do work!
