Forum > Fabrication
making my 73 ford courier go fast, turn, and stop
fastivab6tg25mr:
Installed Hyperco take up springs, I was sick of having to set the rear springs every time I lifted the truck. The springs were almost the same price as getting longer coils but I'm not 100% sure what the spring rate is so I went this route. I could only find plastic centering rings so i made my own aluminum ones.
MTZ:
Crafty! ;DDD
fastivab6tg25mr:
Got to put the beast of a homemade sheet metal brake to work, had no problem bending 38" of 16ga. I'm happy how it turned out.
Ntrain2k:
O0 O0
92CXyD:
Wow, did you prep the hump, did you cut the sheet metal to match the ribbed floor?
Or did you just you tuck under floor edge and weld in place? can't tell in picts. :noel:
Navigation
[0] Message Index
[#] Next page
[*] Previous page
