Author Topic: Should I turbo this Miata-powered Triumph Spitfire?  (Read 81138 times)
awptickes
« on: July 04, 2023, 10:23:28 AM »
I know... The answer is always "yes". Eventually.
So... I always wanted an odd convertible car. I was trolling FB Marketplace and found one. And it looked decent. A 1980 Triumph Spitfire. I read a little more, and apparently it'd been Miata engine/transmission swapped. Cool.
The seller said it smoked a little on warmup, but the smoke went away after it got some heat into it. I didn't know that it had a spectacularly popped head gasket and no coolant, but I tried driving it the 54 miles home anyway. My tow coverage is 50 miles, so all I really had to do was get it 5 miles down the road. I got it 16 miles, the cabin filled with smoke, and I lost all power. Good times.
So, I got it home and saw some good carnage. Then I found a miata head on FB for $140 shipped, slapped it on, and made the thing run again. Now it runs, but it still smokes, this time oil smoke.
« Last Edit: July 09, 2023, 07:09:30 PM by awptickes »
awptickes
Re: Should I turbo this Miata-powered Triumph Spitfire?
« Reply #1 on: July 04, 2023, 10:28:42 AM »
So, I did the valve stem seals. Then I did some little things to make the car a little nicer. Replaced the seat covers, got new gauges from speedhut, and have been driving it a bit.
If I drive it hard it still burns oil, but a lot less. The leakdown is about 10% lost, but it's not horrible to drive. It's very tail-happy, and it runs a 7.58 0-60 MPH, and a 16.19@81 in the quarter, so it's not fast, but it's also not slow.
Also, I must've have really hurt a U-Joint somewhere... Because it makes the u-joint clicking whenever it gets warm. Oops.
« Last Edit: July 09, 2023, 07:10:40 PM by awptickes »
« Reply #2 on: July 07, 2023, 11:11:03 AM »
Pics  O0
awptickes
« Reply #3 on: July 09, 2023, 07:06:03 PM »
Hmm. I'm not sure why the photos didn't show...
ah, BBCode woes.
« Last Edit: July 09, 2023, 07:09:49 PM by awptickes »
« Reply #4 on: July 10, 2023, 01:32:46 PM »
I like this Spitfire, chassis wiring updated avoid the stereotypical Lucas electronics issues?
Like the Gauges, and the classic look, love the exterior colour.
What ECU/EMU are you using?
When are boosting this?
Future upgrade?
« Reply #5 on: July 10, 2023, 05:50:30 PM »
That thing needs a turbo stat!!
MTZ
« Reply #6 on: July 12, 2023, 12:39:19 PM »
Love to see a Triumph getting some love.
its called toering
« Reply #7 on: July 12, 2023, 06:02:03 PM »
^this^
awptickes
« Reply #8 on: July 13, 2023, 06:37:07 AM »
Wiring/Engine Management: It's a complete miata harness, spliced into the Triumph stuff at the spots where it makes sense. Thanks PO!
It's all "stock" miata drivetrain, with a stock spitfire rear diff. 1995.5 Miata engine, transmission, ECU, and harness and a 1980 Spitfire 1500 chassis.
The turbo is coming as soon as I can figure out how to fit it under the hood, which probably won't be until the cold months here in Maryland.
« Reply #9 on: December 15, 2023, 02:07:38 PM »
Any updates, once turbo goes on this thread will be a new addition to our Turbo build database :noel:
