Pages: 1 ... 3 4 [5] 6 7 8   Go Down
Author Topic: 2000 Dakota R/T  (Read 288893 times)
Re: 2000 Dakota R/T
« Reply #120 on: February 11, 2024, 07:24:12 PM »
Yah def I am riching it up
MTZ
  • Webadmin
Re: 2000 Dakota R/T
« Reply #121 on: February 11, 2024, 09:29:29 PM »
looked up my last dyno run results (self tuned, its been a few years) and gave you my actual approach last time which was to just set a target afr that was low enough for safety and good for power all around when under boost, there is always some power to be made when leaning it up a bit but its truly negligible and its best to just keep it simple and chase power with timing not afrs
some spots actually make more power richer due to cool down effect too but i hate overly rich cars. less than 11.2 its just not needed
« Last Edit: February 11, 2024, 09:33:30 PM by MTZ »
its called toering
Re: 2000 Dakota R/T
« Reply #122 on: February 12, 2024, 01:32:26 AM »
I richened it up a bit and went to some dry ground and it rips nicely.
Spun all through 2nd on dry pavement lol
Re: 2000 Dakota R/T
« Reply #123 on: February 12, 2024, 02:24:10 AM »
Mid/upper 11s afr at 7psi
Spinning but still accelerating through 2nd
« Last Edit: February 13, 2024, 04:12:52 PM by random-strike »
Re: 2000 Dakota R/T
« Reply #124 on: February 12, 2024, 12:05:30 PM »
220k miles later and the damn things broken
Re: 2000 Dakota R/T
« Reply #125 on: February 13, 2024, 04:12:31 PM »
« Last Edit: February 13, 2024, 08:29:54 PM by MTZ »
Re: 2000 Dakota R/T
« Reply #126 on: February 13, 2024, 04:28:46 PM »
« Last Edit: February 13, 2024, 08:30:19 PM by MTZ »
Re: 2000 Dakota R/T
« Reply #127 on: February 13, 2024, 09:05:12 PM »
BTW the speedo is off 5mph at 60mph. 80 is about 90 lol
Bigger tires and I can't change it in the ecm its in a different computer I think abs module
Re: 2000 Dakota R/T
« Reply #128 on: February 20, 2024, 01:39:23 PM »
i turned boost up a little bit to about 8 or 9 or so i guess? it ran hard and then randomly it would act like it had a big vacuum leak and run  shitty and i chased my tail for a little bit but i finally figure out what happened.
it blew out the vacuum servo for the cruise control, its weird because it would be a big leak, then later fix itself... then it started not fixing itself at all lol.
everytime i would boost itwould fuck up a again. there was a check valve i nthat vacuum line from the factory but it must not work well enough.
i disconnected the cruise control and added a new check valve to the vacuum line that goes to some other crap in the cab like that vent control
Edit:
This whole post is is autistic af you shouldn't have read it
« Last Edit: February 20, 2024, 10:48:56 PM by random-strike »
Re: 2000 Dakota R/T
« Reply #129 on: February 20, 2024, 01:41:09 PM »
the speedo is off 60mph = 65mph and like 70-80 i wish i could change tire size with HPTUNER but you cant...
https://www.youtube.com/watch?v=u-fgnGSTL3M
Re: 2000 Dakota R/T
« Reply #130 on: February 20, 2024, 04:40:58 PM »
nice ripper  :noel:
Re: 2000 Dakota R/T
« Reply #131 on: February 20, 2024, 07:34:11 PM »
I actually just figured out what the problem was....
Leaky Chinese injectors.... they were leaking really bad you could hear them spraying just by putting ear up yo manifold.
I put the stockers back in until I figure something out. They might be fine anyways.... they are 23.4lb apparently
Re: 2000 Dakota R/T
« Reply #132 on: February 21, 2024, 06:33:18 PM »
How's the AFRs with stock injectors back in?
Re: 2000 Dakota R/T
« Reply #133 on: February 21, 2024, 07:20:27 PM »
A little lean but I'm working on a different issue and it's really bizarre.
The car runs and acts "normal" but after I boost only if it's for a second it runs like 20% leaner then all of a sudden back to normal... could be a day later could ve a few mins
I can't figure out what the fuck is happening.
Like it'll cruise at 13:1. For days... I boost one time wot even for a second and it runs 15:1 for a random amount of time
Re: 2000 Dakota R/T
« Reply #134 on: February 22, 2024, 04:12:27 PM »
I'm hoping it's just in the tune. Without the data logging working it's very hard to see where you are at on the map
Re: 2000 Dakota R/T
« Reply #135 on: February 23, 2024, 12:56:39 PM »
HiProfile on here InjectorNation.com
Re: 2000 Dakota R/T
« Reply #136 on: February 23, 2024, 01:00:37 PM »
sent Jeffrey a message on FB for you it can help ya a bunch on tuning and injectors  :noel:
Re: 2000 Dakota R/T
« Reply #137 on: February 23, 2024, 01:07:37 PM »
Thx
The iac was fucked up and causing me problems too... it was hanging the idle
Re: 2000 Dakota R/T
« Reply #138 on: February 23, 2024, 01:12:33 PM »
What would help me a lot would be how to scale this map.
So basically the stock map reads 14.8 to 105kpa
The Honda map should be like -25vac to 11.4psi
If I could scale the Honda map to this grid. There are also some parameters in hptuners for the map scaling the hptuners doesn't give a description that makes sense it basically just says the same thing as the label.
Re: 2000 Dakota R/T
« Reply #139 on: February 23, 2024, 01:48:19 PM »
This might help but there is zero description of these values and what they do
Re: 2000 Dakota R/T
« Reply #140 on: February 23, 2024, 06:20:07 PM »
I might have found the problem....
The idle air control valve took it out was seriously gummed up like it had never been removed, I got a new one and cleaned the tb and it seems to be better now....
I also put the stock map sensor on to try and eliminate potential issues but that wasn't it...
I'm gangsta tuning the last row for now
I made bullet connectors for the maps lololol
Re: 2000 Dakota R/T
« Reply #141 on: February 24, 2024, 04:50:22 PM »
It's fine now. The iac was fucked up.
It was fucked up so bad it was making me run in circles because the afr would change randomly because of the extra air being let in. Going into boost must have pushed it open and it would randomly start moving again... it was super crusty and shitty looking.
It was so bad I went back to stock map and stock tune and with the correct iac it would barely run. Instead of resetting by disconnecting battery., i drove it around a bit starting and stopping motor and its learning and runs good now.
I should probably switch to the other map again, the gangsta tune at 0 vac sucks for driveability
MTZ
  • Webadmin
Re: 2000 Dakota R/T
« Reply #142 on: February 25, 2024, 08:54:58 AM »
Car gremlins
its called toering
Re: 2000 Dakota R/T
« Reply #143 on: February 25, 2024, 12:24:55 PM »
Bigtime
Multiple problems but I'm getting it sorted I had the wastegate stick open twice
I took it apart and smoothed out the valve and the seat like the say to do to "bullet proof" them. Seems better now
I'm going to buy some bosch Ford "skinny giant" injectors. They are 42lb and pretty cheap. I also have the injector data for them so my tune will make sense
Re: 2000 Dakota R/T
« Reply #144 on: February 26, 2024, 02:14:12 PM »
runs great with stock map and injectors.
i keep having to bump up the fuel at wot at 7psi its still not rich enough, its really wet out and pointless to do anything most of the time for the last couple days
MTZ
  • Webadmin
Re: 2000 Dakota R/T
« Reply #145 on: February 27, 2024, 10:02:42 AM »
Good stuff! I like to go from rich to lean , you might benefit adding a few percentage points to that area and leaning it up instead, I’m always scared of knock
its called toering
Re: 2000 Dakota R/T
« Reply #146 on: February 28, 2024, 04:16:03 PM »
car runs great but can't stand WOT. injectors are totally maxed out at whatever power 7psi wants to make.
my 42s should be here friday i think.
can't do shit until i get them. the stock 24s are maxxx'd
Re: 2000 Dakota R/T
« Reply #147 on: March 04, 2024, 01:24:40 PM »
my 42s should be here today at some point.
truck runs great stock inj just can't handle power.
i think it runs better part throttle with my tune and a little more gas. like 13.5AFR part throttle rather than ~14.7 when the computer controls it
Re: 2000 Dakota R/T
« Reply #148 on: March 04, 2024, 08:52:59 PM »
I put 42s in and did quick math on my newest 36s tune and it runs pretty good
Very rich at wot. Need to do some tuning
« Last Edit: March 05, 2024, 01:48:06 PM by random-strike »
Re: 2000 Dakota R/T
« Reply #149 on: March 05, 2024, 04:00:42 PM »
Got some dry pavement this morning so I did some tuning while running errands. It's about 12.4-12.5 afr and runs pretty good on spring which is about 7psi
I need to do some work on the hit ts running too rich in the hit and I think it's making the turbo spool up slower.
8-9psi felt like 40-50hp gain lol. I'm going to leave it around 9psi and be happy with it.
I don't want to blow out the plenum gasket at least anytime soon.
If it blows ill either weld it or but the plemun kit that is supposed to handle lots of boost
These injectors are great and cheap.
« Last Edit: March 05, 2024, 04:06:04 PM by random-strike »
Pages: 1 ... 3 4 [5] 6 7 8   Go Up
