Pages: 1 ... 6 7 [8]   Go Down
Author Topic: 2000 Dakota R/T  (Read 27017 times)
Re: 2000 Dakota R/T
« Reply #210 on: September 10, 2024, 01:19:24 PM »
i'll probably throw some head gasket sealer in it for a while. its supposed to be good for diesels and my 21 gmc runs 40+psi of boost
GMC 40+ psi boost, diesel?
yeah its a 3.0 duramax. i watched it a few times through the obd2 port and it hit like 42psi
Re: 2000 Dakota R/T
« Reply #211 on: September 15, 2024, 12:53:50 PM »
yah the head gasket "fixer" fixed it. cools like normal. im afraid to boost on it, but the bottle literally says good for diesels, and my 3.0 duramax is 40+psi
also, i had kinda forgot it had this problem when if first got it a couple years ago, the sealer worked for like 2 years including like 6 months of 10+psi
so whatever, maybe i'll fix it right this winter. but i do daily this truck so winter is still boosting weather.
i fixed the two bolts that were broken off in the drivers side exhaust manifold / head
my plan actually worked perfectly, i left the manifold on and used the holes as a guide for the drill bit, drilled them out, took manifold off and tapped the holes with 3/8 bolt and it worked great and they tighten up, manifold doesn't leak when cold anymore.
i should've left the manifold on and tapped the bolt holes in the manifold as well as the head, then i could've left the vbands alone... oh wel
the big problem, and why i didn't want to do this for so long, since after a min  or two of running the heat would fix the leak... now the vbands are leaking  like a bitch and these cheap ones are single use...
i should have two clamps coming monday and then maybe i won't have any exhaust leaks lol
MTZ
  • Webadmin
Re: 2000 Dakota R/T
« Reply #212 on: September 15, 2024, 06:17:34 PM »
it must have a bad head gasket, it runs fine and boosts fine, but its pressurizing the coolant, and got some foam and bubbles.
i'll probably wait a while, but gets some MLS head gaskets and arp head studs, and get the heads rebuilt... since they have a couple bolts broken off in them
damn that always sucks but might as well do it right next time and get everything milled while you are at it, ive wasted so much time in the past trying to do as little as possible to seal a head, you might as well mill, new mls gasket and arps. good looking dog mang
its called toering
Re: 2000 Dakota R/T
« Reply #213 on: September 16, 2024, 03:10:58 PM »
yah thanks on the doggggg hes a great dog.
yeah i might fix it right. the turbo kit is really tight so i don't really want to take it apart.
i have to take off the compressor housing to get the turbo off
Re: 2000 Dakota R/T
« Reply #214 on: September 16, 2024, 03:13:25 PM »
his name is ranger
Re: 2000 Dakota R/T
« Reply #215 on: September 17, 2024, 04:55:51 PM »
well, got new clamps and put them on and now no exhaust leaks maybe for the first time ever lol.
truck runs good, see how long the head gasket fixer holds
« Last Edit: September 18, 2024, 05:18:01 PM by random-strike »
Re: 2000 Dakota R/T
« Reply #216 on: September 23, 2024, 11:43:27 AM »
well obviously i got bored and started boosting on it, and its still ok. lol...
it runs great. my boy who has his permit now loves it when that boost comes on
i also took 2 degrees of timing out of it on the top end incase some detonation would kill that head gasket sauce. these motors don't like timing anways. can't tell the difference between 15 and 17
« Last Edit: September 23, 2024, 11:45:45 AM by random-strike »
MTZ
  • Webadmin
Re: 2000 Dakota R/T
« Reply #217 on: September 24, 2024, 12:26:04 PM »
might as well have fun  ;DDD
its called toering
Re: 2000 Dakota R/T
« Reply #218 on: September 24, 2024, 01:17:23 PM »
haha yah
its a good experiment
Re: 2000 Dakota R/T
« Reply #219 on: September 27, 2024, 12:37:39 AM »
Been doing some part throttle street tuning... Turns out when there are no leaks it needs tuned different lolol
Re: 2000 Dakota R/T
« Reply #220 on: October 02, 2024, 12:36:18 PM »
been boosting and doing some part throttle tuning. its running really good.
it misses sometimes under boost, i really need to put new plugs in it. the oil fucked them up when the plenum leaked
Re: 2000 Dakota R/T
« Reply #221 on: October 02, 2024, 03:52:11 PM »
Nah! just do a tonne of rippers and make the plugs burn themselves clean  :evil:
Re: 2000 Dakota R/T
« Reply #222 on: October 02, 2024, 10:44:21 PM »
naturally
Pages: 1 ... 6 7 [8]   Go Up
