Author Topic: what size oil restrictors are you guys running?  (Read 21096 times)
Zeniceguycrx
« on: May 12, 2009, 10:58:24 PM »
well what ya got going on
The 30psi king of rice
1slow91hf
Re: what size oil restrictors are you guys running?
« Reply #1 on: May 12, 2009, 11:36:49 PM »
stevemode line model  :noel: or .065" jb weld and drill bit edition :noel:
« Reply #2 on: May 13, 2009, 02:56:10 AM »
i just weld the fitting shut and drill a 1/16" hole
« Reply #3 on: May 13, 2009, 05:08:56 AM »
.035 on the DBB CRHA
« Reply #4 on: May 13, 2009, 07:07:10 AM »
what turbo???  -4 is too big. -3 is cool for a journal bearing turbo, They reccomend a .065 to .100 for journal bearings...
I actrually talked to a garett engineer and he told me .035 is fine for BB CRHAs.
Zeniceguycrx
« Reply #5 on: May 13, 2009, 06:25:20 PM »
t3 48/60
sloTeg
« Reply #6 on: May 13, 2009, 08:21:54 PM »
does anybody run restrictors in their Holsets?
1slow91hf
« Reply #7 on: May 14, 2009, 12:59:54 AM »
the sizes given are pretty much flat rate across the turbo world so some may some may not run them
never hurts to have a bit of restriction
« Reply #8 on: May 14, 2009, 01:34:30 AM »
Ive always used -3 lines and .065 restrictor on everything ive cared about. Everything else got the good old 3/8" fuel line with a 1/8" mnpt cap shoved inside it with a 1/8" hole drilled in it. And yes I would run a restrictor on a holset. I dont know about you but at 7500 im pushing close to 85psi of oil pressure.
« Reply #9 on: May 14, 2009, 05:19:53 PM »
what ever size the inside of a aluminum pop rivet is.  on a 14b with no problems
« Reply #10 on: May 15, 2009, 02:22:38 AM »
ever looked at the thing they come off?
do you see restrictors? no way. just rock it
BoostForLife
« Reply #11 on: May 15, 2009, 02:26:47 AM »
Im running a -3an to 1/8npt fitting, then 1/8 to 1/4npt converter, into 1/4 by 12X1.5 fitting on the holset.
I don't think it needs a restrictor, this is on a HX35.
Atticus
« Reply #12 on: May 15, 2009, 03:29:05 AM »
adjustable FTW
« Reply #13 on: May 19, 2009, 04:50:41 PM »
-3 an feed line, .065" restrictor
to4e turbo 50 trim
speedjunky01
« Reply #14 on: May 19, 2009, 11:29:33 PM »
dont run the function 3 restrictor
the one i got is -4an, then had to 90* it then convert -4 to -3
end result:
hope i can make it stop pissing oil
JB weld restrictor FTW
ifly87
« Reply #15 on: May 20, 2009, 01:26:13 AM »
JBweld restrictor ftl, I've chowed a turbo because the jbweld inside the fitting came loose and plugged up the hole. Now I tap threads into a fitting, thread a set screw into it with red locktite, and drill a .060 hole in the setscrew.
Lol...Fags
« Reply #16 on: May 20, 2009, 10:00:15 AM »
Take a riviet, remove the shaft and drop it in the line.
Blammo.. Oil restrictor.
Also seen guys use washers from rivets...no issue
« Reply #17 on: May 20, 2009, 10:41:38 AM »
worked for me, just make sure to use a rivet out of whatever material your fittings are
SirDragsAlot
« Reply #18 on: May 20, 2009, 11:00:01 PM »
i bought a 1/4 npt needle valve meant for hydraulic applications,  simply adjust to your needs.  perhaps i will use some kind of pressure gauge to tune the oil flow when my project is ready
« Reply #19 on: May 21, 2009, 02:39:14 AM »
fill fitting with weld, drill with push drill and small drill bit.
done.
another win for the welder
