Pages: 1 2 [3]   Go Down
Author Topic: Better than any halfcore you could ever put into a crx!!!! Tucked crx radiator.  (Read 189246 times)
Re: Better than any halfcore you could ever put into a crx!!!!!!
« Reply #60 on: March 10, 2010, 03:54:08 AM »
I'll accept donations of v1.0
Kalam
« Reply #61 on: March 15, 2012, 11:09:32 AM »
Setup in a 92 Integra
« Reply #62 on: March 15, 2012, 02:00:50 PM »
I know your a noobs and all, but excellent work on the fab skills. Is that some fluxcore action I see? You need a noon post like ASAP
« Reply #63 on: March 15, 2012, 02:14:08 PM »
Yeap   :noel:
« Reply #64 on: March 16, 2012, 10:06:20 AM »
No excuse: Date Registered: April 12, 2009, 12:16:43 PM
But I second the fabbing. Looks like it was meant for a DA.
« Reply #65 on: March 16, 2012, 01:54:28 PM »
I've had the parts riding around in my trunk to do this for quite a few months, I have a da as well.
4door89
« Reply #66 on: June 10, 2012, 06:04:57 PM »
I ended up doing the samething, but aren't you worried about the lack of support now that there's no lower radiator support there?
I did a 1"x2" bar going across the front.
Sedrostyle
  • Turbine Noob
« Reply #67 on: July 17, 2014, 01:52:40 AM »
Dead but I want this.
« Reply #68 on: July 17, 2014, 08:56:57 AM »
May be dead but I know a project with an aluminum version of that radiator going a heavily boosted civic, thanks to this thread.  :noel:
« Last Edit: July 17, 2014, 08:58:30 AM by 92CXyD »
Sedrostyle
  • Turbine Noob
« Reply #69 on: July 20, 2014, 01:45:58 PM »
Mmm hmmm. Its a badass setup. My buddy is trying to talk me out of it.
Saying just to get a skank 2 or stock rad.
But this would be out a the way. And super JDM. : SD
« Reply #70 on: July 20, 2014, 03:22:18 PM »
FUck your buddy.  He sounds like some douche bag VW owner. :noel:
« Reply #71 on: March 09, 2015, 02:06:05 AM »
Bump. I'll be doing this in my car with a stock crossmember.
walter
« Reply #72 on: April 05, 2015, 09:01:32 PM »
Just ordered scirocco radiator, i'll try to make samething on my car.. just was wondering what hoses to use on my D16 SOHC engine..
« Reply #73 on: April 06, 2015, 01:03:05 AM »
Should be the same, since the outlets of radiator is on the same side as stock Civic.
walter
« Reply #74 on: April 06, 2015, 10:31:58 AM »
sohc use 28mm if i remember correctly instead 32mm as b series and this scirocco radiator..i think it's time to weld aluminum too  :noel: i will post pics when it arrives this week.
« Reply #75 on: April 06, 2015, 10:47:32 AM »
My stock size silicone coolant hoses fit with a little lubricant.  :noel:
« Reply #76 on: April 06, 2015, 07:35:32 PM »
My hose fit with a little lubricant.  :noel:
That's what she said.
« Reply #77 on: April 06, 2015, 11:13:24 PM »
Yep nice and snug  :noel:
walter
« Reply #78 on: April 08, 2015, 05:45:55 PM »
china 1 layer hoses should works good  ;DDD
walter
« Reply #79 on: April 14, 2015, 09:56:40 AM »
received it! looks good...need a lot of work though..
walter
Hi! im in the point to adapt scirocco radiator, my question is about what hoses should i run because i want to use a silicone hoses.
I assume stock D series hoses will not works, does it?
One first page "I used the stock 91 teg lower radiator hose and it worked perfect. For the upper hose I used 1 91 teg upper hose, and a piece of another teg upper hose."
Also used an inline radiator filler for the upper hose.  :noel:
walter
mi engine is a D16z6  :-\
walter
nop, upper is different , inner diameter too, time to fab work.  :-\
Pages: 1 2 [3]   Go Up
