Author Topic: Idling with IACV?  (Read 14777 times)
DreaMeR
Idling with IACV?
« on: May 19, 2009, 08:34:43 AM »
Long story short my IACV plug disapeared and Idk where it is. So I decided to disable it (or the CEL really) and just run without, now the car idles like shit, so what should I do to get a decent idle down?
Re: Idling with IACV?
« Reply #1 on: May 19, 2009, 09:54:21 AM »
open the Tb tiny bit with the idle screw.
DreaMeR
« Reply #2 on: May 19, 2009, 11:42:32 PM »
its the screw thats like right next to the vac nipple right?
« Reply #3 on: May 20, 2009, 12:14:03 AM »
That's a fine adjustment screw.  You might have to make a big adjustment via the throttle stop.
« Reply #4 on: May 20, 2009, 02:49:37 AM »
 Adjust throttle cable or stop. Or I have a box of iacv 2 wire plugs. send me 10 dollar and I send plug
DreaMeR
« Reply #5 on: May 20, 2009, 09:37:27 AM »
I could go to the junkyard and snag one for free, but I did adjust the stop which help, now I need to figure out whats going on when I give it gas it wants to die...need a dp so I can figure out these afr's...
« Reply #6 on: May 20, 2009, 12:28:38 PM »
I like corn flakes
« Reply #7 on: May 20, 2009, 12:53:53 PM »
It's in the TB.
turbo4life
« Reply #8 on: May 21, 2009, 03:53:17 AM »
it will still idel like shit and be gay wehn driving  it will be eigther on or off type of thing during cruise speeds
End the fake food.
« Reply #9 on: May 21, 2009, 10:05:50 AM »
I have no IACV on my beater, currently.  Starts, idles, runs like a champ.  The problem you are seeing is likely due to big injectors that don't atomise very well, that a functioning IACV can smooth out.  There are also a couple other causes, that's just the first one that leaps to mind.
« Reply #10 on: May 24, 2009, 01:54:17 AM »
I like corn flakes
I like coca pebbles
