Author Topic: Silly noob question about cable to hydro conversion  (Read 10257 times)
danwjmu
« on: May 20, 2009, 07:33:08 PM »
Ok so I'm restoring the crx to its former glory and I want to put my Z6 shit in there.  I'm swapping harnesses out and all that, since I don't have a crx harness anyway.  I'm going to make a bracket to mount the clutch master cylinder under the dash, ok that's not a problem.  My question is "what do I do about the vss?"  I want to retain my crx cluster, but the hydro trans has an electronic vss.  Is the cable vss swapable into the hydro trans... or what can I do to correct the situation?  I'm assuming the crx cluster has an electronic vss built into it and it sends the ecu speed info...  WHAT DO I DO?!!  Help a noob nog plz.
ok
Re: Silly noob question about cable to hydro conversion
« Reply #1 on: May 21, 2009, 01:32:04 AM »
you ask and pay me. Simple concept.
Loserkidwac
« Reply #2 on: May 21, 2009, 12:10:29 PM »
YEa cable vss will fit or you can swap in a SIR cluster they use the electric vss
2002 BMW 530i Sport
1992 Mazda Miata
1998 K2500 454
buk9tp
« Reply #3 on: May 21, 2009, 12:27:27 PM »
MECHANICAL AND ELECTRONIC VSS'S ARE 100% INTERCHANGABLE EVEN A FUCKING RETARD LIKE ME KNOWS THAT!!!!
TALK TO CHRIS HE USUALLY HAS 1 OR 2 ON HAND FOR SALE... PRICES RANGE FROM 20 TO 30 SHIPPED
« Reply #4 on: May 23, 2009, 08:37:39 PM »
no.
buy a cable drive.
What I used to have on hand......
I have a Z6 tranny I just bought out of a CRX, has cable drive installed which I will be removing for a proper VSS unit.
« Last Edit: May 23, 2009, 08:39:31 PM by crttaz »
buk9tp
« Reply #5 on: May 26, 2009, 09:03:37 PM »
yup just buy the entire thing i told you hit up chris...
dont get the ones with plastic gears :?:
and be careful tighting it down (i dont even bolt them in i just set the fucker in)
a 2 year old can fucking snap them and most of the time they have hairline fractures you cant even fucking see :P
QikEnuF
« Reply #6 on: June 01, 2009, 10:01:04 AM »
The moral of this thread is buk is a faggot.
BoostForLife
« Reply #7 on: June 01, 2009, 11:50:42 AM »
Put an 2000 Si Cluster in it and have a nice smooth speedometer.
« Reply #8 on: June 01, 2009, 12:59:09 PM »
How hacked up does that look.
