Author Topic: Can anyone help identify information on this turbo. More Info!!!  (Read 15117 times)
89shithatch
Got one off of an IH DT466 engine. cannot find much information on them. would like to find out what flange type, and rough power output capabilities this turbocharger has. any info would be appriciated. I believe it is a TO4E17 turbocharger. it is not internally gated so i could run an external gate with my setup. image of what the turbo looks like. http://www.turbosystem.com.mx/imgprods/size2/4652255006.JPG. Thanks. BTW could not get too much info on the unit because it is buried in the truck still. did not a/r 60 m24 on the comp side tho.
« Last Edit: May 26, 2009, 05:37:11 AM by 89shithatch »
esi42
89shithatch
Re: Can anyone help identify information on this turbo.
« Reply #2 on: May 26, 2009, 05:36:46 AM »
compressor side is marke a/r .60 and exhaust side is marked 1.24. can anyone give me any information as to what trim etc with those numbers?
89shithatch
Re: Can anyone help identify information on this turbo. More Info!!!
« Reply #3 on: May 26, 2009, 02:46:11 PM »
anyone?
« Reply #4 on: May 26, 2009, 03:52:07 PM »
The pic is tiny, but it appears to be a T04, with a T4 Exhaust flange, and a HUGE turbine side, as can also be seen with the 1.24 turbine a/r.
Unless you want to put a different exhaust housing on it, this is not a good turbo for your setup.
89shithatch
« Reply #5 on: May 27, 2009, 02:53:59 AM »
how bad would it be on a vitara setup? aroun 20lbs.
« Reply #6 on: May 27, 2009, 10:03:03 AM »
The actual turbine blade isn't huge, but the housing is. I would have to guess that even with a log mani, you wouldn't see meaningful boost till 5500-6000.
Toysrme
« Reply #7 on: May 31, 2009, 03:09:22 PM »
I wonder when a turbo with a 1.24 A/R turbine would spool on a D16Z6 vitara setup ???
t3 with a 1.24 or 1.06
« Reply #8 on: May 31, 2009, 03:11:33 PM »
It would be a T4 frame turbo.
caged
« Reply #9 on: May 31, 2009, 04:50:30 PM »
You could just blank off one of the scrolls and that would half the actual A/R. If you didnt i dont believe you would be able to spool it >6200rpm.
Kain
« Reply #10 on: May 31, 2009, 06:38:59 PM »
if you dont want it, ill buy it. lol
89shithatch
« Reply #11 on: May 31, 2009, 11:47:54 PM »
150 shipped.
