Author Topic: $1000 to spend! What would you buy?  (Read 16305 times)
« on: May 25, 2009, 10:29:22 PM »
Ok
Sold the beater....
I have money to blow.... I am gonna spend it on my car....  What would you get...
I have a 94 civic coupe ex
Z6 Vitaras and Tuner Toys
Stock head with stock cam
Xtd stage3 clutch
Egay cast mani
Evans performance .57 trim turbo
Jackie chan wastegate
RC 550's
Things I was thinking about buying...
M-factory LSD-  (Would be nice)
Baller turbo mani and down pipe
Zex 59100 cam  and use stock valve springs
Zex 59000 cam and some better than stock valvetrain  (All my money)
Good clutch
What would you buy?  This car is a daily driver....
Has anyone from here tired the Zex 59100 cam?  Likes, Dislikes....
Re: $1000 to spend! What would you buy?
« Reply #1 on: May 25, 2009, 10:33:31 PM »
Lsd and clutch!
« Reply #2 on: May 25, 2009, 10:33:50 PM »
LSD. also a tial diaphragm. i dont like chinamans
« Reply #3 on: May 25, 2009, 10:34:07 PM »
I would get:
-a colt regrind cam.
-some bigger injectors
- a 4bar
- and a race gas tune.
hotrex
« Reply #4 on: May 25, 2009, 10:35:01 PM »
if ur spending money on a cam get the 59300.   if it was me thats the route id go.
ur cast mani and jackie chan wg and turbo are fine.   get a new intake mani too.
work on the head. the rest of the setup is fine
90dx
« Reply #5 on: May 25, 2009, 11:04:26 PM »
59300 Cam, Crespo springs and retainers,good clutch, 3-4 bar map sensor if your running stock and  a case of beer for the install.
« Last Edit: May 25, 2009, 11:06:56 PM by 90dx »
« Reply #6 on: May 25, 2009, 11:23:56 PM »
A real throttle body/manifold
g_shok
  • SuperSport
« Reply #7 on: May 25, 2009, 11:24:28 PM »
high class hookers and alcohol
« Reply #8 on: May 25, 2009, 11:36:03 PM »
OOO hookers and blow, that is a solid choice.
« Reply #9 on: May 25, 2009, 11:36:53 PM »
Cant go wrong with either :noel:
« Reply #10 on: May 25, 2009, 11:51:40 PM »
Ported z6 IM w/ 70mm tb and spacer, 59300 cam and maybe some custom springs.
I'm sure that Chris M could source all of that for than 750usd. still have some money for any unforseen problems during your build.
« Reply #11 on: May 25, 2009, 11:56:37 PM »
I also can cnc machine stock throttle bodies 3mm larger bore/plate for 80 bucks if you send in cores. Thats for b/d/h/f series. K series/v6 Honda stuff is 100 since its a little more labor to do them.
Im also going to make spacers for the smaller size throttle bodies also for the budget guys who are wanting to just bore over stock units.
« Reply #12 on: May 26, 2009, 12:47:33 AM »
Duh, binge on crack and hookers.
Evan
« Reply #13 on: May 26, 2009, 04:56:46 AM »
truthfully..i would invest...it would be worth it in the long run  :yes:
« Reply #14 on: May 26, 2009, 05:00:39 AM »
This is rhmt not boring.com
« Reply #15 on: May 26, 2009, 05:05:03 AM »
The lsd is a good choice, but making more hp isn't always the best choice. Whats your suspension setup??
I'd be looking at what could help get the power your making to the ground, ie adj upper control arms, replacing old worn out bushings and joints, or installing a complete energy suspension bushing kit,i personally felt this was one of the best upgrades i did, and a good shock/spring combo. This would also allow your car to hook alot better, and make your tires last alot longer.  It really makes the car alot more enjoyable to drive.
« Reply #16 on: May 26, 2009, 12:24:55 PM »
Fuck the Zex cam, all they do is spool late.  There are better, actual turbo cams, for the money.
How about ditching the ching chong meow fail snail?
« Reply #17 on: May 26, 2009, 03:53:42 PM »
Buy another beater to flip?
realAgentMurdoc
« Reply #18 on: May 26, 2009, 04:12:49 PM »
buy an MFactory LSD from me and I might have some crower springs retainers from a Y8 in the garage somewhere if you are interested.  ;D
« Reply #19 on: May 26, 2009, 04:16:08 PM »
I would buy the cam and new valvetrain
For once I agree on something hotrex says.
hotrex
« Reply #20 on: May 26, 2009, 09:29:37 PM »
id roll it up in a knot lube it with vaseline and pound my shaft with it :somb:
SQ is the SQUAD
« Reply #21 on: May 26, 2009, 11:27:23 PM »
i got some rear disc brakes of my 94 gsr sedan parts car
SDRAWKCAB
  • D series BALLA!
  • Rhino
« Reply #22 on: May 26, 2009, 11:32:30 PM »
if your getting a cam and springs 59500 is the way to go.
« Reply #23 on: May 27, 2009, 12:20:04 AM »
Barrel roll bars.
« Reply #24 on: May 27, 2009, 12:27:07 AM »
I have jk motorsports traction bars, koni yellows, tien greens, and a rear sway bar off a 4door integra.  And also a getto ebay camber kit...
This is the better idea I think since I have the ES master kit for my car and have not installed the harded press in type bushings....
Camber kit
Pay someone else to put in the ES kit
Good alignment and install new lower ball joint
Looking  :-\
The other thing will have to wait for now....
« Reply #25 on: May 27, 2009, 12:39:05 AM »
I like the prothane complete kit better then the ES one.
« Reply #26 on: May 27, 2009, 04:07:43 AM »
cocaine and hookers
« Reply #27 on: May 27, 2009, 05:23:26 AM »
Doug a input shaft bearing  :-*
« Reply #28 on: May 27, 2009, 02:46:39 PM »
hookers and ice c-c-c-c-c-cream
Fixed  ;)
