Which Valve cover should I use?
Black one sprayed with Bedliner Paint?
The red wannabe marble one?
HHH
CRX
OCZC
PBT FTMFW!
Pages: [1] 2 3 ... 9   Go Down
Author Topic: Jay's 90 CRX build. A6/Y8 Vitara, Holset. Parting out. Please see FS sec.  (Read 210814 times)
Alright.  I finally got the ball rolling again with my build on the CRX.  its been 2+ years and with the new baby makes it hard.
A6/Y8 Mini me turbo Bitches
at least I still have the scraper I still drive around for fun.
http://www.realhomemadeturbo.com/forum/index.php?topic=26.0
Build Specs:
90 Hella Fast.
A6 block
FJ custom length I-Beams
75mm Vitaras
Stock y8 SOHC VTAK Head
ARP headstuds from Lightning Motorsports (they sold the kit with 1 y8 stud for the swap.  They actually shipped me 2 sets on accident.  dont know what to do about the second one)
MLS head gasket
Stock Y8 intake mani (may send this to chris to try to work some magic with it)
Mars Galaxy spec 4 puck unsprung disc (custom piece.  21 spline count hub with a 212mm disc)
Pluto pressure plate
Im pretty sure I forgot hella shit.  I have a few  turbos for this thing and not sure what I am going to use so far.  Also turbo mani will be coming from CSaddict.  not sure if im going to go top mount or log..
here is the doner vehicle.  I bought this shit all stock a long time ago for $300
thats how it sits right now.
here are a few pics of when it was last running
the e bay gaskets
Galaxy disc with pluto pressure plate
88si trans i scored from chris for some tasty lumpia that i cooked for him.  i even got personal delivery.  This nog is top notch
vitaras in FJT I beams compared to stock
the a6 big block!
rods look good
copper sprayed hg
y8 meets a6
pic of vtak solenoid
clutch on
misc pics
poll will be up about the next 2 pics.  which valve cover should i use?
This is for Chris.  Too bad i dont have this one anymore
the garage before
« Last Edit: January 11, 2010, 01:23:17 AM by ApexSilver06MR »
98redcavz24
  • NE Crew
Looks good. ZC
Looks good. ZC
did you ever get my pm about the keys?
esi42
Mini me!!!!
realAgentMurdoc
gangsta.... black cover wins
Word. Shit is ganster. Send me the motor? :)
You should paint the whole car black. Rattlecan that bitch. And Fuck your stripe  O0
« Last Edit: May 30, 2009, 06:41:02 PM by glustic »
90boostdaccord
black cover.  shit is looking good.
turbo1.5
Nice to see some progress!
 :yes:
alright motor is in.  intake manifold is not on.....im still debating on using the y8 intake mani.
i just need to order a log now and a few things here and there...
AbaZ
  • Out of retirement
    • R-HMT
A log? thats not very creative
Get a 12 pack and bust out the wirefeed. It usually inspires most
98redcavz24
  • NE Crew
Jeff always coming out with something sig-worthy :mexi:
Yes, I got your pm, I will pm you back today. I have to check the machine
maybe an elephant trunk
what is your plans for the dizzy on that engine?
I tried using a z6 dizzy and I a hard time getting the ignition to work (look at the front page b/c of the use of vise grips). :-[ ::) ;D
I was told to use a y8 dizzy with z6 electronics to make it work.  :)
i had an a6 dizzy that i was going to use for it but i needed the money and sold it for $50.
im still debating on converting to obd1.  im pretty sure that i will use an a6/b6 dizzy
the intake mani gasket that came with the kit didnt fit too well and the ports on the gasket  were screwy and blocking the ports partially on the head.  I just had to order an edelbrock intake mani gasket for a y8 part number 15005 from kragen for $6.  looks like a decent piece.
y8 head uses the 16 valve non vtec sohc bolt pattern
so you need for obd1 a d15b7/d15b8 dost for bolt on action
Thanks Chris M. ;D
What about the cam pulley should I use the y8 stock or y8 adjustable?
If you have a y8 cam use oem cam gear
thanks  ;D
Also if you stumble on a y8 dist all you have to do is have a set of obd1 dist plugs and you can repin the obd2 dist to obd1 pins. Internals are the same
Hence why when you convert an obd2 car to obd1 all you need
is
jumper harness
obd1 ecu
jarebear667
i like your masking skills :yes:
i have the same build going!
midwest HMT!
I like how the car has about 50 different colors of paint on it. True  O0 build
thanks.  we used it as a grafitti wall for a year.  the body work will be situated after everything is finished.  Paint will be flat black.
isnt the paint under the hood sexy?
Would have been if it didnt look like widebodys dash....
Should have gone black yo. But fuck looks, its all about performance!!
just cause when people look at your shit...
all they think is, "baby got back"  lol
At least you dont have a huge ass spoiler on it, and some 24" rims.
You can fit 24" rims on a Civic??
enikolayev
Good to see progress man! I've been working on my vitara as well. Need tranny and clutch.
Pages: [1] 2 3 ... 9   Go Up
