Author Topic: not reading while datalogging..freelog crome  (Read 12747 times)
trevor72
  • trevwhore
« on: May 31, 2009, 11:50:15 PM »
I have the latest crome and freelog versions but very little is registering.  I have the 4post to usb on the ecu and my com ports are set to com4 with good connections. Only running the narrow band O2 for now till i get a LM1 to ecu cable, but shouldn't i see rpm, iat....etc even just idling???
« Last Edit: June 01, 2009, 12:27:15 AM by trevor72 »
Re: not reading while datalogging..freelog crome
« Reply #1 on: May 31, 2009, 11:54:02 PM »
did you cut the j1?
trevor72
  • trevwhore
« Reply #2 on: June 01, 2009, 12:02:53 AM »
don't recall, but i did cut j12 isn't that the one that needs cutting?
« Reply #3 on: June 01, 2009, 12:24:17 AM »
Move to Engine Management?
« Reply #4 on: June 01, 2009, 01:34:00 AM »
Or just delete out of hand?
BoostForLife
« Reply #5 on: June 03, 2009, 03:25:07 AM »
in freelog go to setting and under data command, set it to crome 1.4
Don't forget to enable Quickdatalogger +RTP plug in with Crome
« Reply #6 on: June 03, 2009, 01:16:12 PM »
nice background any more picts. of the chick. ;D
« Reply #7 on: June 03, 2009, 02:24:16 PM »
LOL, that was the first thing I saw, I was like hey, that looks like a reflection of tits!
trevor72
  • trevwhore
« Reply #8 on: June 03, 2009, 05:27:41 PM »
I'll try this,
i thought at least once i had both programs open and RTP enabled but will try again and report back.
