Author Topic: How do you guys do your pcv system?  (Read 17562 times)
enikolayev
« on: June 02, 2009, 01:31:45 AM »
Since my engine is on the stand awaiting a few parts i thought i would make some holes in my valve cover
Holes drilled at an angle
Removed that sheet metal guard thing - whatever its called
Made a bigger gap here for more airflow
Made one big hole here instead of the few little ones
Cleaned up and awaiting JB weld
The concoction is all done and drying now.
Not sure if i cut out enough material, or too much here. What is the general consensus on amount of holes in valve cover?
Re: How do you guys do your pcv system?
« Reply #1 on: June 02, 2009, 02:59:23 AM »
you better fucking put that sheet metal baffle back on there otherwise after your first pull all your oil will be in your catch can or intake, assuming you wont have it drain back to your pan
enikolayev
« Reply #2 on: June 02, 2009, 04:15:48 AM »
Don't worry its all back together. Just drying atm.
Toysrme
« Reply #3 on: June 02, 2009, 10:27:31 AM »
on engines that do not have them i install baffles on the stock locations, eliminating the need for stupid fucking catch cans that only treate the symptom, not fix the fucking problem.
enikolayev
« Reply #4 on: June 02, 2009, 07:36:44 PM »
Well here's the thing completed. I'm not baller enough to whip out the torch. Bro could have welded aluminum fittings to it at work, but i like the jb weld touch personally.
The reason for this thread was to see how much baffle was necessary to be safe from loosing oil.
« Reply #5 on: June 02, 2009, 08:16:56 PM »
JB pimp right there.  O0
« Reply #6 on: June 02, 2009, 09:28:24 PM »
As mush as we all like JB i dont think thats going to work when it gets hot its probably going to come loose.  :-\
90boostdaccord
« Reply #7 on: June 02, 2009, 09:32:49 PM »
+1
enikolayev
« Reply #8 on: June 02, 2009, 10:05:51 PM »
The ultimate test of JB weld
« Reply #9 on: June 03, 2009, 09:46:43 AM »
I think its a good idea, but you have to redo it a little better.
speedjunky01
« Reply #10 on: June 04, 2009, 10:26:33 AM »
+1
-1
jb weld will hold forever! ive used it on my oil pan, bro's auto tranny, turbo oil feed line ect ect
« Reply #11 on: June 04, 2009, 08:11:48 PM »
+1
-1
+1
zc> oc> jb weld > *
« Reply #12 on: June 04, 2009, 11:53:41 PM »
+1
-1
+1
zc> oc> jb weld > *
+1
esi42
« Reply #13 on: June 05, 2009, 07:42:36 AM »
When we powder coat valve covers, we drill out the old rivets and remove the plate to clean the crap out.  Then drill new holes and put in new rivets.
Toysrme
« Reply #14 on: June 05, 2009, 11:30:57 AM »
+1
If they cleaned it very well when they started i disagree. When I wa N/A in the lexus I went small ports. Filled my intake ports with JB Weld - it wasn't a problem. It also was alot of work trying to get it back out when I decided to turbo. It did not come out easily.
