Author Topic: BRE & now ECU Flash Fail  (Read 26833 times)
FreshDA9
« on: June 15, 2009, 06:38:59 PM »
ok i have had BRE on multiple computers in the past but i restarted my laptop about 6 months ago and cant get it to work now but works on my desktop that i restarted a month earlier?
when i open BRE i get this error message
""bre.exe has encountered a problem and needs to close. we are sorry for the inconvenience. if you were in the middle of something, the information you were working on might be lost.""
running windows xp service pack 3 all my other software works crome/hondata/dsm link/turbo edit, tried this on pgmfi but i never get any responses there.
Thank you.
« Last Edit: June 18, 2009, 04:47:27 PM by FreshDA9 »
Re: BRE install issue
« Reply #1 on: June 15, 2009, 07:44:02 PM »
why not use TE?
FreshDA9
« Reply #2 on: June 15, 2009, 09:20:48 PM »
friend of mine is using BRE on his car and wants to stay that way but for some reason now my laptop wont run it but my desktop does? he is boosting it and needs it tuned. i stoped offering people bre and turbo edit but hes a friend. also i have never used TE on a pr3 or pw0 nor do i think i have a base map.
« Reply #3 on: June 15, 2009, 09:40:29 PM »
It can be a millons of things. Mine works on windows xp sp3, so thats not the problem.
What version of BRE do you have?
FreshDA9
« Reply #4 on: June 15, 2009, 10:35:22 PM »
i have tried all 3 versions listed on pgmfi.org i have the beta on my desktop but my desktop screen is currently broken. i beleave i have the beta on my laptop right now after trying the others i just havent deleted this one.
FreshDA9
Re: BRE & now ECU Flash Fail
« Reply #5 on: June 18, 2009, 04:53:10 PM »
well looked threw all my software and found out not only does BRE crash on me so does ECU Flash??/
was looking over some 3g eclipse maps for a customer and my ecu flash crash's every time now. we used his laptop and he sent me over the wrong map file but with any bin it crashes i took some screen shots of the error codes that appeared.
all other programs run fine??? anyone have any ideas?
« Reply #6 on: June 19, 2009, 12:03:48 PM »
It's a work machine.  You set a system restore point, correct?
FreshDA9
« Reply #7 on: June 19, 2009, 08:06:02 PM »
solely for tuning not an actual work laptop. i wiped it out completely,  i hope!
if you weren't trying to reflash a euro 04 sti, you wouldn't get that error
works in rom raider just fine this was a base map i had sitting around so was seeing if it messed up on all maps and it did. wasnt actualy flashing a ecu.
« Reply #8 on: June 19, 2009, 08:07:42 PM »
So it's a work machine.  Did you set a system restore point?
FreshDA9
« Reply #9 on: June 19, 2009, 10:50:49 PM »
sorry jd thats a negative on the restore point checked and it says my restore point is today. also couldnt find my windows disk when i restarted it so im using a bootleg copy buddy said he has a legit copy and he is a computer freak so i might let him go at this.
« Reply #10 on: June 19, 2009, 11:02:16 PM »
I'd reformat, reinstall everything the way I like it, and set up system restore.
FreshDA9
« Reply #11 on: June 19, 2009, 11:03:03 PM »
noted and will do and get back with you
« Reply #12 on: June 19, 2009, 11:05:29 PM »
Grooooooooooovy
FreshDA9
« Reply #13 on: July 16, 2009, 08:48:03 PM »
Well after all this time i finally got to reboot windows
Results -
 Ecu Control works great no more error crashing.
BRE - keep getting this error when i download any version of BRE.
any clue? Thanks guys
« Reply #14 on: July 16, 2009, 11:26:56 PM »
Find out what Ben Ogle programmed BRE in and download the runtime libraries.
93turbo16
    • J-K-Tuning
« Reply #15 on: July 16, 2009, 11:50:24 PM »
I assume you have the .net framework stuff installed. It needs it to run BRE.
J-K-Tuning
FreshDA9
« Reply #16 on: July 17, 2009, 01:07:03 AM »
Yes i Do
JD i will look around and even try to send him an email
« Reply #17 on: July 17, 2009, 01:23:19 AM »
Do so, he's a bright dude and has worked hard at BRE.  I'm sure he can be of assistance.
I'd start by looking at BRE in the pgmfi.org forums, sir.  He'll have some contact info thrown up.
FreshDA9
« Reply #18 on: July 22, 2009, 12:17:47 AM »
Ok i havent herd from Ben yet but i did get BRE to open on my laptop now but im still having issues. my framework was 2.2 or something like that updated now to 3.5. now when i open it BRE says "Compiler Error , Version 2.0 is not a compatible version"???? (im running 2.2.4). then it says "BRE, Error while opening". then after that message it opens and will load my bin's and everything. Now im bench testing it with my ostrich but no matter what i click on or off it wont detect an emulator. my crome and tuner pro detect it. any input?
O and i gave up on pgmfi a long time ago this same thread was started the same day i put it on here and there is only 1 reply over there. none of there threads get answered in my opinion and thats not just my post thats other users also.
« Reply #19 on: July 22, 2009, 12:53:05 AM »
Hrm.
What COM port is your Ostrich coming up as?
FreshDA9
« Reply #20 on: July 22, 2009, 10:11:45 AM »
Com 4 is what i have it set as i have also tried to change it to 1,2,3,5 still nothing. maybe it has somthing to do with this weird error im getting? i usually keep my Hulog at com 1 and Ostrich at com 4.
« Reply #21 on: July 22, 2009, 11:16:13 AM »
I don't think it's your problem, but FTDI drivers can be wierd.  Get on FTDI's site and run their FTDIClean utility, then reinstall your Moates drivers and try again.
FreshDA9
« Reply #22 on: July 23, 2009, 03:45:36 PM »
i did FTDI clean again and reinstalled the drivers and Negative still doesnt work for BRE? crome still detects and sends the rom also tuner pro also detects the ostrich. still no word from Ben.
« Reply #23 on: July 24, 2009, 11:53:42 AM »
It's got to be some sort of software conflict, and not an interface problem.  I don't know what Ben programmed BRE in, if you can dredge that from pgmfi.org or BRE's site you can find the most up to date libraries for that language and install them at which point it should work.
Just like eCtune is scripted in .NET so you have to download the .NET framework (libraries) for it to run, there are software libraries for various flavors of VB, C, C+, C++, Java, etc.  What is likely is that you have an older version of these libraries that causes a glitch, or you have an up to date version that has become corrupted.
« Reply #24 on: July 24, 2009, 11:56:19 AM »
Okay, I just reread this thread since I obviously lost track of what's going on.  BRE is on .NET, and you've already done that.  I suspect your runtimes are corrupt.
Go to add/remove programs and remove the .NET framework, as well as BRE.  Reboot.  Download and install .NET 3.5.  Reboot.  Download and install BRE.  Pray for success.
FreshDA9
« Reply #25 on: July 25, 2009, 04:03:51 PM »
Well Sir!!!!!!!!!!!!!  Its finally FIXED!!!! that did the trick JD your a fucking machine dude lol.
« Reply #26 on: July 25, 2009, 06:19:01 PM »
Sorry it took so damn long to get everything figured out.
FreshDA9
« Reply #27 on: July 25, 2009, 08:45:09 PM »
lol its cool i dont do much of BRE but my best friend wants his new turbo setup on. good looking bro!
