Author Topic: TPS is NOT getting voltage.. 0 at multimeter, 0% on datalogs  (Read 15290 times)
I am really confused at this point.. I just finished installing my 780cc injectors and the car was running like shit. So I look at datalogs, idle is at 19.9 AFR, this is a tune JD did for someone else on a similar setup, so I decided to make my own basemap in crome gold.. still no good. then I notice the TPS says 0% when i rev it up in the logs.. check the voltage and I get 0 volts at any position.
So, I've checked the actual wire all the way to the ecu, and it's good. I tested it by grounding a 9volt battery on one end meeting the sensor and checked it at D11 on the ecu side.. it's all good.
Not sure what to do at this point.. I tried another ECU and TPS .. what now???
Re: TPS is NOT getting voltage.. 0 at multimeter, 0% on datalogs
« Reply #1 on: June 17, 2009, 03:01:21 PM »
Which tps wire did you check?  The B+ source or the signal wire back to the ecu?  Do you have a good ground at the tps plug?
« Reply #2 on: June 17, 2009, 03:09:16 PM »
so far I have checked voltage between the grn/blck and yel/blu.. was only .25 volts
i get nothing from the blck/red wire from either end.
« Reply #3 on: June 17, 2009, 04:36:39 PM »
TPS plug disconnected, multimeter set to ohms, check continuity between red/blk wire tps plug pin 2, and ecu plug D pin 1.
Check continuity between pin 3 TPS plug, yel/blu and Plug D pin 10 ecu side.
Multimeter back to Volts, with key on/engine off you should have power (.5v ish) at pin 1 of the tps plug, grn/blk.
Ignore D11, its SG2 for the ecu, but not where you need to be.
« Reply #4 on: June 17, 2009, 07:57:30 PM »
OHMs from red/blk -> D1 = 4.52
OHMs from yel/blu -> D10 = counted down to .86 then up to .94 and I ended it there
Volts from grn/blk = 0v  with key on
« Reply #5 on: June 17, 2009, 08:07:39 PM »
You have PM.
« Reply #6 on: June 17, 2009, 08:54:02 PM »
fixed it!! thanks robbmiester
« Reply #7 on: June 17, 2009, 08:55:30 PM »
What was the problem?
« Reply #8 on: June 17, 2009, 09:10:36 PM »
i'm not exactly sure to be honest.. I THINK one of the pins at the obd2->obd1 jumper harness for the TPS wasn't making a connection. who knows.  after messing with the pins Robb referred (D10, D1, etc.) it worked. 3 solid hours of my life, gone forever  :-\
« Reply #9 on: June 17, 2009, 09:15:11 PM »
You better find out what happened, it may test the soles of your shoes soon
« Reply #10 on: June 17, 2009, 09:28:37 PM »
what? i've been hit by a coil before.. hurts like shit, but it's nothing to worry about.
« Reply #11 on: June 17, 2009, 09:40:17 PM »
LOL, I think he means that you better get it figured out so that it doesn't happen again, and leaves you walking. :P
« Reply #12 on: June 17, 2009, 09:59:33 PM »
it's all good, I will probably swap the whole engine harness eventually.. I see them at the junk yard all the time.
« Reply #13 on: June 17, 2009, 10:17:27 PM »
Ding ding ding
Nothing like being broke down over some stupid shit
It is guaranteed to happen when your about to show off for some hot ass chick
« Reply #14 on: June 18, 2009, 09:16:56 AM »
Did you hot-glue your obd2>1 jumper harness?  I always hot-glue the back side of the connectors to prevent that exact problem.
As shown here.
