Author Topic: Newest record  (Read 21699 times)
d-rail
Re: Newest record
« Reply #1 on: July 02, 2009, 01:14:07 AM »
WOOOOOOD
notfastcrx
Re: Newest record
« Reply #2 on: July 02, 2009, 01:21:26 AM »
such a sick install.
d-rail
Re: Newest record
« Reply #3 on: July 02, 2009, 01:29:29 AM »
The whole setup is sweet as hell and the way they did the valve cover is fucking awesome.
Re: Newest record
« Reply #4 on: July 02, 2009, 01:45:37 AM »
Fuckin Vitara's are nasty
Re: Newest record
« Reply #5 on: July 02, 2009, 02:09:57 AM »
qft
when do we get to see it wasting a blue devil
Re: Newest record
« Reply #6 on: July 02, 2009, 02:58:19 AM »
what was the slew rate???? 22-25?
Re: Newest record
« Reply #7 on: July 02, 2009, 03:08:03 AM »
its a dynapack. thats a mid 400hp car at best on a roller dyno.
nice setup regardless.
d-rail
Re: Newest record
« Reply #8 on: July 02, 2009, 03:16:59 AM »
I disagree. If setup correctly dynapacks are the best in the field. There is only 1 that I would say reads stupid high off the top of my head but I cant even remember the name of it.
Re: Newest record
« Reply #9 on: July 02, 2009, 03:21:19 AM »
Church's dyno
Dyno's are tools and vary. Plenty of ways to cheat them also
If the car run's 9's thats what matters
Power is in the head. Good #'s whoever ported the head.
d-rail
Re: Newest record
« Reply #10 on: July 02, 2009, 03:51:55 AM »
If that thing runs 9's i'd shit. Makin that kind of power will probably be hard to put to the ground from what I've seen without a really nice suspension setup and an excellent driver.
Re: Newest record
« Reply #11 on: July 02, 2009, 04:18:40 AM »
That high reading dynapack can be brought into line if the slew settings are shared.
I've seen a high compression LS go from 140whp to 160 whp just by changing the slew settings.
Unless everyone uses the same settings, you cannot compare the Dynapack numbers, but the are a GREAT tuning tool, if not the best for loading and no slippage.
d-rail
Re: Newest record
« Reply #12 on: July 02, 2009, 04:24:26 AM »
I trust what you say but even if they were fuckin with the slew for better numbers, They couldn't have played with it enough to make a HUGE differance IMO. 30-50 horse is the most I've seen fucked out of those dyno's.
Re: Newest record
« Reply #13 on: July 02, 2009, 04:29:28 AM »
evans dynapack reads 100+hp higher then a dynojet. youre kidding yourself if you think its only 30hp.
d-rail
Re: Newest record
« Reply #14 on: July 02, 2009, 04:33:32 AM »
dynojet's are the highest reading I've ever seen. The only other dyno I'd trust besides a dynopac is a Mustang dyno. Your an idiot if you think their is 100 horse difference.
Re: Newest record
« Reply #15 on: July 02, 2009, 04:41:30 AM »
yes dynojets are def the highest reading  ::)
car makes 745@31psi on evans dynapack and traps 140mph
goes to nrg tech for a retune and it makes 680@29psi on a super duper high reading dynojet and proceeds to trap 144
so the car made 65 less hp on a dynojet and trapped 4 mph higher. yea youre right, dynapacks dont read high or anything.
oh and before the retune we took the car to a dynojet to see how high dynapacks really read. it made 745@31psi on a dynapack and it made 596@26psi on a dynojet.
« Last Edit: July 02, 2009, 04:45:24 AM by Corey »
d-rail
Re: Newest record
« Reply #16 on: July 02, 2009, 04:48:37 AM »
I'd have to see proof to believe that shit. I'm really not trying to be an ass but most people I've talked to have preferred a dynopack over anything else because of accuracy unless it's a diesel in which case they proffered other dyno's.
Re: Newest record
« Reply #17 on: July 02, 2009, 04:52:25 AM »
why would i make this stuff up? the only thing a dynapack has on a roller dyno is the fact that its a hub dyno so you dont have issues with tire spin. i would never trust dynapack numbers, itll only leave you dissapointed when you go to the track.
d-rail
Re: Newest record
« Reply #18 on: July 02, 2009, 04:56:25 AM »
I don't know you so why wouldn't you lie? I'm not saying your wrong but I've seen what I've seen and truck dynapack over anything and the only other I trust is a mustang. But I would guess that the biggest thing would be proper calibrations
Re: Newest record
« Reply #19 on: July 02, 2009, 05:01:45 AM »
i dont benefit from proving dynapacks read high, i have no reason to lie. its my buddys car. when that car goes to the track and traps 135mph ill believe that dyno doesnt read high.
what are the specs on that setup? what turbo? how much boost? whats in the head?
d-rail
Re: Newest record
« Reply #20 on: July 02, 2009, 05:07:54 AM »
Go to d-series.org. Has all the specs on the car. Read everything and you'll believe the dyno pedro. Here's the link to the whole car bub:    http://d-series.org/forums/forced-induction/113062-speedfactory-09-vitara-d16-build.html
Re: Newest record
« Reply #21 on: July 02, 2009, 05:19:55 AM »
eh maybe hes got that one properly calibrated. i didnt realize it was a 6262 and he had the custom length rods to up the compression, 550 isnt terribly unbelievable. still doesnt change the fact that most dynapacks read high, even if that one is properly calibrated.
d-rail
Re: Newest record
« Reply #22 on: July 02, 2009, 05:28:06 AM »
I'm not saying your wrong and I'm right on this shit, I'm just going by what I've seen just like you. I just have my own preference like everyone else I recon. REGARDLESS that fucking car is sick. I want a valve cover like he has. It makes perfect sense.
BangBusMaster
Re: Newest record
« Reply #23 on: July 02, 2009, 07:41:15 AM »
I personally watched two cars from that Dynapack make considerably less power on a Dynojet.  I would take a Dynapack over a Dynojet, but the diff. needs to be figured out.
Re: Newest record
« Reply #24 on: July 02, 2009, 09:35:03 AM »
Good read even though I still have reservations about Bisi's cams. :?:
Re: Newest record
« Reply #25 on: July 02, 2009, 10:00:38 AM »
 ;)  Dirty Ds done dirt cheap...........   :P
Re: Newest record
« Reply #26 on: July 02, 2009, 10:07:02 AM »
you talking about vadim's and joe's shit? i saw it too.
Re: Newest record
« Reply #27 on: July 02, 2009, 10:50:59 AM »
dyno's will read extra high if you are going downhill because gravity is making horsepower/tq
Re: Newest record
« Reply #28 on: July 02, 2009, 11:22:22 AM »
Call it what you want to call it, the car made ~470whp last year and went mid 10s @ 139mph @ 2600lbs. On the SAME dyno it just made almost 100whp more.
Hi, low or other dynapacks are very repeatable, as such I see a car that will now have a chance at 9s, on vitara's.
Re: Newest record
« Reply #29 on: July 02, 2009, 11:51:21 AM »
Yup.  All of the dyno reps (except the shady Dynojet liars) at PRI agreed that the Dynapack 4000 was all around the best dyno made, "but since you can't afford one - no offense, no one can - let me show you what our unit has to offer."
