Author Topic: car wont run right (more specific inside)  (Read 8044 times)
« on: July 25, 2009, 03:42:59 PM »
i have a fmu on this setup...
every time i turn on the car, it will idle fine, but when i get up to driving speed and keep it a static throttle position, it will hesitate like its a fuel issue. i can clear up the hesitating with some WOT but only with WOT.  the problem persists for lik 5 minutes then goes away.  also, it will die when i come to a stop at stoplights...  the hesitations happen only when i've shut the car off and last only 5-7 minutes.  its anoying as hell.  any ideas?
Re: car wont run right (more specific inside)
« Reply #1 on: July 26, 2009, 08:07:30 PM »
dont know about afr's... fuel pressure is good. could it be a bad/going bad tps or iiac?
« Reply #2 on: July 29, 2009, 09:19:07 PM »
any ideas at all??
d-rail
« Reply #3 on: July 30, 2009, 06:40:09 AM »
get it tuned with something decent so you can see what the fuck your car is doing.
Ravage70
« Reply #4 on: July 30, 2009, 09:21:34 PM »
you cant fix your problem blind, get something to check your afr
Its like walking into a dark room full of naked men and 1 woman bent over and trying to put your dick in the right hole. Chances are your gonna try and hang yourself when the lights come on.
