Author Topic: EF aftermarket upper control arms  (Read 9742 times)
« on: August 11, 2009, 04:42:23 AM »
so i got the cheap ebay suspension kit and it comes with upper control arms that are a little different then the stockers. the stockers seem to pivot a lot easier. they have like a little sleeve that allows the UCA to pivot, the new afermarket ones dont really work the same. i torqued them to the recommended specs but the fuckers dont move at all. is this right? like i cant move them up or down at all, well i can force it really hard and it moves but it doesnt seem right.
Re: EF aftermarket upper control arms
« Reply #1 on: August 11, 2009, 03:59:54 PM »
so you replaced 20 yr old worn out a-arms/bushings with new ones and they seem stiff?  haha  :?:
« Reply #2 on: August 11, 2009, 04:48:40 PM »
there are no bushings like the old ones, just a steel sleeve that doesnt work like the old ones. it doesnt pivot at all
« Reply #3 on: August 11, 2009, 04:56:11 PM »
what? a picture of the two would help alot.
« Reply #4 on: August 11, 2009, 05:01:54 PM »
this is what they should look like.
and here are what the bushing's look like.
1slow91hf
« Reply #5 on: August 12, 2009, 11:25:41 AM »
did you put a good poly lube on them when you installed them cause if not it will be tighter then a broke O0 wallet
