Author Topic: Fuck this shit...  (Read 12361 times)
SgtB
Re: Fuck this shit...
« Reply #30 on: August 21, 2009, 07:05:21 PM »
I know what you're saying, but you're thinking about it in the wrong frame of reference. It's ALL in the coils at the generator, and has little or nothing to do with the load.
« Reply #31 on: August 21, 2009, 07:51:44 PM »
Ah, I see your point now. Gotcha.
« Reply #32 on: August 21, 2009, 08:38:57 PM »
That wouldn't work worth a shit. They're too small and they're designed to increase the frequency, which is pointless.
Works great, which is why everything being produced these days is inverter drive, and freq drives come in hp flavors higher than anything you'll ever own.
Increasing the frequency is not pointless, you can re-gear the machine for max torque/low speed, and still be able to turn up the machine a decent amount (limited by what the bearings will like on the drive side, I imagine) without having to fool with gearing.  ALL newer welders are inverter machines, and you can ask the guys using them if they like them as they can build *any* waveform, allowing all sorts of cool shit to be accomplished.
The machine has like 30 speeds by gear plus a variable drive on the motor already.
So do you regear for everything, or use the onboard freq drive?   :mexi:
« Reply #33 on: August 22, 2009, 01:13:51 AM »
i have a 6hp centuty/gould made in usa single ph 220v i'm not using for anything.
where you located? What you want for it?
