Author Topic: WTKN /2 Turbos = 1 Supercharger NSFW  (Read 17647 times)
Emperor
« on: August 26, 2009, 02:36:12 PM »
Can somebody tell me which Turbos (I need 2) emulate the output from a eaton m45?
 :yes:
« Last Edit: August 26, 2009, 02:37:43 PM by Emperor »
RHMT Boost everything
-Cars
-Bikes
Re: WTKN /2 Turbos = 1 Supercharger NSFW
« Reply #1 on: August 26, 2009, 03:18:32 PM »
linky no worky
« Reply #2 on: August 26, 2009, 03:20:35 PM »
What the fuck a m45 is tiny, you tryint to TT a lawnmower?
Emperor
« Reply #3 on: August 26, 2009, 03:56:49 PM »
no
have a yota to boost
boost level around 8psi :-[
the reason is simpel
a m45 works pretty bullet proof on this engine (09,- 1GFE)
I dont want spend 3000-5000$ for a used TTE Supercharger kit------>Sucks
Homemade Twin turbo = WIN
alot cheaper
no power loss ---->belts are sooo nasty
i can crank up the boost easy
and
If a supercharger Fail ------->it cost you a arm or leg for repair<------Turbos can be found everywhere
-Cars
-Bikes
« Reply #4 on: August 26, 2009, 03:58:37 PM »
no
alot cheaper
and
Just put one turbo then. No reason in putting two.
Emperor
« Reply #5 on: August 26, 2009, 04:03:13 PM »
i know 1 would be enough
but
all good things come in pairs  ;D
you see? 2 BOOBS :?:
NO Serious  ;D
I want 2 cause its the only one in germany + twin turbos are sexy
-Cars
-Bikes
« Reply #6 on: August 26, 2009, 04:09:20 PM »
but
NO Serious  ;D
I see no boobs
Emperor
« Reply #7 on: August 26, 2009, 04:17:21 PM »
Did Hotrex steal my linkas?????
WTF! HOTREX HAS HERPES
i post tmrw new pics for ya horny NIGNOGS
-Cars
-Bikes
« Reply #8 on: August 26, 2009, 04:21:22 PM »
but
NO Serious  ;D
That (two turbos) is retarded.
BRIAN MP5T
« Reply #9 on: August 26, 2009, 07:29:52 PM »
You make no sense.
You want to turbo because it's cheaper than a Eaton SC.
You want to turbo but it will be harder than making this car run with a turbo
You want TWO turbos because they remind you of BOOBS.
The Solution... Get an actual pair of boobs, Get one turbo..
Emperor
« Reply #10 on: August 27, 2009, 02:45:17 PM »
You make no sense.
OH Man ,irony is not your favorite subject huh?
2 small charger spool same like 1 big one
its more easy (for me) to fabricate two 3-1 header instead of one euqal length 6-1 header
the Gen I 1GGTE come factory with twins (but nothing fit to the 3rd gen)
btw
the Topic is
Iam looking for 2 turbos as a replacement for a M45
« Last Edit: August 27, 2009, 02:55:34 PM by Emperor »
-Cars
-Bikes
Emperor
« Reply #11 on: August 28, 2009, 07:37:40 AM »
thanks man ;D
-Cars
-Bikes
« Reply #12 on: August 28, 2009, 03:22:03 PM »
You make no sense.
Fuck Eatons S/C use a SC14 of a '95-'97 Previa 1.4L or 84 cid. mount it remote like another a/c compressor. You can turn on of with a switch. Us a recirculation valve to relief pressure and allow air the S/C when turned of. No oil lines, no extra coolant lines or any major exhaust modification.
Just like I did on my '92 CX hb : http://www.realhomemadeturbo.com/forum/index.php?topic=651.0 (BTW as soon as I get some free time and a working camara I'll post vids.) ;D
« Reply #13 on: August 28, 2009, 03:27:51 PM »
I'm sorry 92cxyd you have a great idea but the execution was horrid. I'm all for home made, but fuck me.
QikEnuF
« Reply #14 on: August 28, 2009, 04:16:00 PM »
Dizznt insulate 92cxyd.  Heem is hemi from Deebo hood.  Deebo rape your talk hole.  Heem front page hemi, you back page whore
« Reply #15 on: August 28, 2009, 11:48:18 PM »
Man, this shit is getting old!
Emperor
« Reply #16 on: August 29, 2009, 10:59:15 AM »
sounds nice but NO
-)SC14 non existant in europe
-I dont want the power loss from a S/C (even i love the sound)
-a turbosytsem is much cheaper to upgrade
i want copy the m45 output cause its safe and i can run with a Fuelcutdefender only ;D
after a while i plan to upgrade the whole system with an AEM F/I and a set of 1GGTE Rods/Piston
-Cars
-Bikes
