Author Topic: keep blowing vc gasketts??  (Read 11048 times)
deeznutts
« on: August 27, 2009, 08:34:37 PM »
ok everytime i run the car hard it boost it blows the vc gasket,
my question is will a pcv system keep this shit from happening??
fuck xeno
Re: keep blowing vc gasketts??
« Reply #1 on: August 27, 2009, 08:36:45 PM »
Probably. Vent the vc good. Also, I've had similar problems before when I just put the gasket on with no sealant. Now I glue the bitch to the head. Now it doesn't leak at all.
deeznutts
« Reply #2 on: August 27, 2009, 08:53:24 PM »
the first one had rtv on it and i mean 8psi on this ls and that bitch shot all the way out on tha front i thought i blew tha bitch up all i saw was oil smoke ..
fuck xeno
« Reply #3 on: August 27, 2009, 09:03:45 PM »
So how exactly is your vc vented now? On my miata I have a hose hooked to the PCV and it goes straight to atmosphere, no catchan or nothing. Breather has a filter on it, nothing else. I used to run both of these to a catchan and it would fill the can with 6oz of oil in a month. Must have been too restrictive. Now I run them both open as described and no oil leaks or blow by. Haven't put oil in it in a month, and I check today and it's right on full.
deeznutts
« Reply #4 on: August 27, 2009, 09:07:38 PM »
right now its hella rigged got a hose off the breather dumped into a coke bottle before it just had a filter on it and that shot would just shoot it off under boost
fuck xeno
deeznutts
« Reply #5 on: August 27, 2009, 09:47:29 PM »
think im getting way to much blow by??
it doesnt smoke well i take that back after a hard run it does smoke some but then clears up prob do a compression test and see wats up wit that
fuck xeno
« Reply #6 on: August 27, 2009, 09:49:09 PM »
Leakdown test. If it's the rings, all that oil on them seals them up good so it will show good compression. :)
deeznutts
« Reply #7 on: August 28, 2009, 11:29:38 AM »
aight thanks
fuck xeno
« Reply #8 on: August 28, 2009, 01:38:58 PM »
Dude, take the black box on the back of your block off, cut a hole in it, jb weld a 5/8" barb in it and run that and the 3/8 line you would be running for your pcv, and the line off the vc all to a snach can and dont even have to fuck aroud with all that shit. It will only be a temp fix but it will work until you get your shit straightened out.
