Author Topic: My turbo 342 build(updated again new numbers and dyno vid)  (Read 41010 times)
79fairmont
Re: My turbo 342 build
« Reply #30 on: November 07, 2009, 01:47:41 AM »
Well we finally got it in the car and running! This run was at 7 psi of boost from a 67mm turbo, with 15-16 degrees of timing thru an aod! Theres quite a bit left in the car but the owner (me) is getting nervous and we'll probably not push it alot further maybe a little higher in the rpm range to see where it levels out.
Re: My turbo 342 build(updated with numbers)
« Reply #31 on: November 07, 2009, 02:17:35 AM »
nice  ;D
« Reply #32 on: November 07, 2009, 03:01:15 AM »
That's torque delivery.
79fairmont
« Reply #33 on: November 07, 2009, 04:28:45 PM »
I still have a stock fox throttle body on it too.. I need to finish up a few things and cam designer says cam will make power to 6500 and it looks like it will, I'll update numbers after we make a few more pulls with it.
« Reply #34 on: November 07, 2009, 04:39:20 PM »
Looks badass, damn that torque LINE.
On a side note, I have a few 302's, one's a 68 block, other a 67. Just threw away 68' 289 that was locked up this summer. HEAVY damn engine.
90turboteg
  • Rebuildin turbos
« Reply #35 on: November 07, 2009, 11:49:37 PM »
ya i have a 85 4 eye fox with a mildly built 289 out of a 68 mustang, idk what kind of power those blocks can take, if its not much then i was going to go with a mexican block or the mod 4.6 thats been siting forever at my shop... anyone know anything about 289s?
« Reply #36 on: November 08, 2009, 11:20:39 AM »
289 and 283 were thick walled beasts
As were pre-69 302.  Much better than mexican block hype.
« Reply #37 on: November 08, 2009, 11:54:59 PM »
My hatred of minorities only extends to the French, and slavic women's sexual ethics, Jon.  Leave my brown skinned Southern nog brothers out of this.
90turboteg
  • Rebuildin turbos
« Reply #38 on: November 09, 2009, 12:35:54 AM »
think my 4 eye fox with the 289 needs a hx55 then :noel: has a forged bottom end eagle stroker kit and bored over .020 has cast iron heads and roller rockers, plus the demon carb is blow threw ready....
79fairmont
« Reply #39 on: November 09, 2009, 07:23:15 PM »
Fuck that demon carb! I messed with one a customer brought in a while back on a blow thru sbc nothing but issues. Had to rework the whole carb almost. Everything else looks good though!
ochoa
« Reply #40 on: November 10, 2009, 04:15:22 AM »
Love the setup. Wanna do a similar build to my 88gt starting this summer. I only wanna do it once thought, My friend who works at a shop said hes seen many  :mexi: block pushed past 500 split I guess they make anchors that hold it all together, but im saving up sor some high $ mill maybe a Dart. Right now im switching the car to carb so I will prolly go with a blow thru setup
79fairmont
Re: My turbo 342 build(updated again new numbers and dyno vid)
« Reply #41 on: May 10, 2010, 10:43:02 PM »
New numbers and vid in first post.
« Reply #42 on: May 10, 2010, 11:13:04 PM »
QFT, C9 and before is where it's at
« Reply #43 on: May 10, 2010, 11:35:56 PM »
Tick tock tick tock...   O0
« Reply #44 on: May 10, 2010, 11:40:06 PM »
i love this build,and would love to do something simaler soon. O0
« Reply #45 on: May 11, 2010, 12:42:53 AM »
Alex is the new trollomatic
79fairmont
« Reply #46 on: May 11, 2010, 07:26:47 PM »
My only question is will this block outlast bigdaddyvtec's transmission.
« Reply #47 on: May 11, 2010, 07:29:28 PM »
Not if he blows it.   O0
« Reply #48 on: May 12, 2010, 02:31:26 AM »
shit your worse then me. and im the jobless one....
ps this thing rocks
« Reply #49 on: May 12, 2010, 02:53:07 AM »
8.5 months and counting, ut im taking it out to freshen it up for the summer in the next couple weeks
Cadracer
« Reply #50 on: May 12, 2010, 03:17:37 AM »
I have a 351 midland block fully deck line bores and all surfaced trued. Got it in a bunch of stuff i bought have the complete rebuild kit for it and some nice v/c and oil pan. Let me know if your interested
79fairmont
« Reply #51 on: May 13, 2010, 09:35:32 PM »
If it was a windsor I would be interested.
