Author Topic: dudes with dsm turbos  (Read 27983 times)
AJxr
  • i aint ur buddy pal
« on: September 08, 2009, 09:27:58 PM »
are you mofos running an oil restrictor on your average honda engine with dsm turbo?
90 hatch
magik123
Re: dudes with dsm turbos
« Reply #1 on: September 08, 2009, 09:32:27 PM »
didnt with my t28, no smoke
didnt with my t25 smoked on decel, think it was my shitty return line b4 i changed it tho.
There seems to be a restrictor built into these things in the oil feed hole, correct if wrong??
Dserieshatch
« Reply #2 on: September 08, 2009, 09:48:54 PM »
Im pretty sure all the mitsu turbo's have a restrictor built into the oil feed
« Reply #3 on: September 09, 2009, 12:21:34 AM »
They have some minor restrictors built into the bearing, same as journal bearing Garretts.  The stock oil feed line has an 1/8" restrictor built into it.  Balance shaft delete (raises the oil pressure through the roof, at or over 100 psi in the higher rpms) and an unrestricted -4 AN feed line is known to cause oil smoking problem in a very small handful of cars.
I say run the thing as is, but if it smokes install a restrictor in there before you put ANY miles on it and destroy the turbo with coking, which in turn can damage your engine too.
AJxr
« Reply #4 on: September 09, 2009, 06:29:45 AM »
thanks guys, starting off with no restrictor, and a -3 feed. unsure of what fitting im using to go from -3 to the CHRA.
90 hatch
« Reply #5 on: September 09, 2009, 08:16:19 AM »
no problems with -3AN lines and 14b's
« Reply #6 on: September 09, 2009, 10:43:00 AM »
my 16G has the restrictor right in it.
« Reply #7 on: September 09, 2009, 11:05:40 AM »
I put my restrictor in your MOM.
« Reply #8 on: September 10, 2009, 01:05:31 PM »
Wait, you mean like a 1/8" wide...penis? I hope not... :-X
« Reply #9 on: September 10, 2009, 01:06:57 PM »
That's the ID, anyway.
« Reply #10 on: September 10, 2009, 01:20:20 PM »
lol, that makes sense. ;D
TTC
« Reply #11 on: September 11, 2009, 08:30:12 AM »
I had to use one with my 14b or it would smoke. Was a tired old turbo tho.
