Author Topic: Turbo Calculator  (Read 71920 times)
Frank
  • N00B *Read Intro Sticky*
  • RickP is Rick Potter and is a tool!
    • Squirrel Performance
Turbo Calculator
« on: March 11, 2009, 06:42:33 PM »
Hi folks.  I am sure some of you used this on the old website.  I figured I would post my creation again.  I have some new maps that will be posted up tonight.
http://www.squirrelpf.com/turbocalc/index.php
I am glad you all have started a new forum!  RickP is tool and I have more then my share of run ins with him!  All he cares about is money.
Thanks,
Frank
Frank Katzenberger
Squirrel Performance - Home of the best turbo calc!!!
Turbo Mopar Forums - Home of the best Turbo Dodge Forums!!! http://www.turbo-mopar.com
Re: Turbo Calculator
« Reply #1 on: March 11, 2009, 06:46:58 PM »
someone needs to come up with a JD calculator.  We would own all your base.
« Reply #2 on: March 11, 2009, 06:53:57 PM »
JD operates on FREEbase
« Reply #3 on: March 11, 2009, 06:55:57 PM »
is that some kind of hack?   :P
CivicOCD
  • Let me dumb it down for you
« Reply #4 on: March 11, 2009, 11:26:42 PM »
I love this calculator, but I'm still in the self teaching mode for some of the finer points, like expected VE at what RPM's to expect with what engine ect. ect.
I've spent a ridiculous amount of time trying different combo's with it.
thank you kindly though for a very useful and time saving tool...although I'm not 100% confident in my accuracy on all my input data.
"quotquotFaster, faster, until the thrill of speed overcomes the fear of death."quotquot
-Hunter S. Thompson
Frank
« Reply #5 on: March 12, 2009, 06:20:38 AM »
I don't know how much fuel tuning you do, but one of the best ways to find your VE is to look at your fuel pumping efficency.  I don't know what kind of engine management you are using, but let me know if I can help.  Assuming anything but 100% is always going to be close enough sometimes.  The other thing you can do is make it match the shape of your HP curve and make the peak around 90-95% percent with the lowest around 78%.
Frank Katzenberger
michigan_soler
« Reply #6 on: March 18, 2009, 11:36:14 AM »
« Reply #7 on: March 18, 2009, 05:38:41 PM »
Pretty neat... it takes most of the thinking out of compressor maps (assuming your inputs are correct).  This is the closest thing I could get to a decent looking compressor map.
« Reply #8 on: March 19, 2009, 01:37:57 PM »
heres another good one i just found.
http://www.not2fast.com/turbo/glossary/turbo_calc.shtml
I use that one to play with b/c you can DL to your computer and not have to be logged in.
special ed
« Reply #9 on: March 30, 2009, 06:21:23 PM »
haha i got a couple entries in, winged one, then went "uuuuuhhhhhhhh, nvm"
i wish i understood this more, i have a 1.8t and would really like to figure out the best goals on the stock turbo.
crx-ecutioner313
« Reply #10 on: April 18, 2009, 01:35:00 PM »
pretty close
toyolla86
« Reply #11 on: October 27, 2009, 02:59:01 PM »
seriously. some of this stuff i just dont get. like how to read the chart at the bottom after you choose your turbo.
twin50 son. get some
and stop acting like a muslim
« Reply #12 on: November 09, 2009, 09:30:40 AM »
It's realy not that hard, it is just a graph of the turbo's output at a given rpm and pressure. Like a dyno graph but for the turbos compressor.
toyolla86
« Reply #13 on: November 10, 2009, 12:39:32 PM »
so when i plug in the 16g that im running now it spikes just before the little graph of ovals. and almost at 90 degrees
and when i plug in the ko3 that im thinking about getting it spikes right in the middle of the graph. and at a lower angle
so which one is better according to this graph.
engine is 1.6
going for 250 hp
4500 ft elevation
7500 redline
which side of the graph is rpms and which side shows boost
« Reply #14 on: November 10, 2009, 02:26:09 PM »
on the left is PR=pressure ratio=(Atm+boost)/Atm.
the bottom of the graph is indirectly rpms. expressed in CFM, Kg /s , or lbs./min (Vol. rate)
I usually figure out what the desired Vol. rate per 1000rpms then multiply by what ever the 2,3,4,5,6,7.....etc x k rpms you are looking at.
toyolla86
« Reply #15 on: November 10, 2009, 04:31:23 PM »
that makes sense.
but still too many numbers to transpose into our system to make sense.
« Reply #16 on: November 11, 2009, 01:18:54 PM »
What I got for my turbo at 380HP with 110*F post-IC temps.
toyolla86
« Reply #17 on: November 11, 2009, 03:41:39 PM »
now could you explain what all of it means
« Reply #18 on: November 12, 2009, 07:52:03 PM »
toyolla86
« Reply #19 on: November 13, 2009, 01:44:57 AM »
wow that is sick.
very in depth.
Adam Lofton
« Reply #20 on: March 04, 2010, 11:14:09 PM »
It means he's running dangerously close to surge and well out of the efficiency island.
« Reply #21 on: March 09, 2010, 06:08:53 PM »
Thought I throw this link up for turbo ID. by measurement. ;D
http://fc3spro.com/TECH/TURBO/tmodels.html
Supercharger Performance
« Reply #22 on: June 17, 2010, 01:58:12 AM »
I just updated my calculator to do Turbo and twincharged calculations :
Including wastegate size, turbo size, intercooler size, hotside and cold side piping , boost pressure for your power target and all the fuel math you'd need to pull it off (injectors, pump, feed and return lines).
http://www.superchargerperformance.com/the-power-calculator
It also tells you other info like maximum safe redline for your bore/stroke combo which is really cool and volumetric efficiency (since someone asked about this) at your stock peak power rpm... if you want , you can also get your VE at any data point you want through the tuning tab (which recommends AFR and total timing figures based on your VE so the VE is calculated and displayed there too).
« Reply #23 on: June 24, 2010, 11:08:44 PM »
Not that all the other bells and whistles you mention aren't erroneous, too, but that claim right there is dumb as shit and can't be expressed with a simple applet.
« Reply #24 on: March 27, 2012, 07:44:29 AM »
Not a turbo Calculator but a good place for Garret base turbo spec.
« Reply #25 on: January 01, 2013, 07:56:30 PM »
http://horsepowercalculators.net/ and http://horsepowercalculators.net/the-horsepower-calculator
Used the second link and found the exact info. I worked out on paper for my twincharge setup works.
The Holset map for He351ve is better than I've seen everywhere else.
And my SC14 map looks good too.
$10 or so for this calculator and it gives you a lot of info., including meth inj, home brew fuel, suggestions of sizing the complete system, part by part.
I like this calculator the most for the comprehensive maps.  :noel:
« Reply #26 on: September 23, 2014, 07:17:39 AM »
New turbo calculator Borg Werner MatchBot to play with  :noel:
http://www.turbos.bwauto.com/aftermarket/matchbot/index.html#version=1.3&displacement=2&CID=122.04&altitude=500&baro=14.502&aat=75&turboconfig=1&compressor=70s75&pt1_rpm=2000&pt1_ve=85&pt1_boost=5&pt1_ie=99&pt1_filres=0.08&pt1_ipd=0.2&pt1_mbp=0.5&pt1_ce=66&pt1_te=75&pt1_egt=1550&pt1_ter=1.18&pt1_pw=NaN&pt1_bsfc=0.43&pt1_afr=11.5&pt1_wts=300&pt1_wd=83&pt1_wd2=74&pt1_wrsin=69033&pt2_rpm=3000&pt2_ve=95&pt2_boost=10&pt2_ie=95&pt2_filres=0.1&pt2_ipd=0.2&pt2_mbp=1&pt2_ce=70&pt2_te=73&pt2_egt=1600&pt2_ter=1.36&pt2_pw=NaN&pt2_bsfc=0.45&pt2_afr=11.5&pt2_wts=320&pt2_wd=83&pt2_wd2=74&pt2_wrsin=73635&pt3_rpm=4000&pt3_ve=100&pt3_boost=15&pt3_ie=95&pt3_filres=0.12&pt3_ipd=0.3&pt3_mbp=1.3&pt3_ce=74&pt3_te=72&pt3_egt=1650&pt3_ter=1.61&pt3_pw=NaN&pt3_bsfc=0.48&pt3_afr=11.5&pt3_wts=340&pt3_wd=83&pt3_wd2=74&pt3_wrsin=78238&pt4_rpm=5000&pt4_ve=100&pt4_boost=17&pt4_ie=92&pt4_filres=0.15&pt4_ipd=0.4&pt4_mbp=1.5&pt4_ce=76&pt4_te=71&pt4_egt=1650&pt4_ter=1.81&pt4_pw=NaN&pt4_bsfc=0.5&pt4_afr=11.5&pt4_wts=368&pt4_wd=83&pt4_wd2=74&pt4_wrsin=84681&pt5_rpm=6000&pt5_ve=105&pt5_boost=17&pt5_ie=90&pt5_filres=0.18&pt5_ipd=0.5&pt5_mbp=1.8&pt5_ce=72&pt5_te=70&pt5_egt=1650&pt5_ter=1.98&pt5_pw=NaN&pt5_bsfc=0.52&pt5_afr=11.5&pt5_wts=400&pt5_wd=83&pt5_wd2=74&pt5_wrsin=92044&pt6_rpm=7000&pt6_ve=105&pt6_boost=17&pt6_ie=90&pt6_filres=0.2&pt6_ipd=0.6&pt6_mbp=2&pt6_ce=66&pt6_te=70&pt6_egt=1650&pt6_ter=2.18&pt6_pw=NaN&pt6_bsfc=0.55&pt6_afr=11.5&pt6_wts=400&pt6_wd=83&pt6_wd2=74&pt6_wrsin=92044&
NathanBrazil
« Reply #27 on: December 16, 2014, 01:52:35 PM »
Thanks,
Frank
Hi!! Could you please post a working link of your website? it is by far the best turbo calculator iv seen so far!
Tnks!
