Author Topic: which head is better pm3 or pm8  (Read 16149 times)
turboblack2door
« on: September 13, 2009, 11:26:31 AM »
I am swapping motors in my dd beater. I have a d15b7(pm8) and a d15b2(pm3) the b2 has bad valves and a good bottom end and the b7 has a good head and a broken piston. Which would be best for my to4e 50trim dd?
93 Honda Civic Del Sol -F22A6, H22 trans, Bisi rods, Aris pistons, Hondata S300, 1200cc RC injectors, e85, Koni Yellows, Ground Controls, fuck my expensive hobby
Re: which head is better pm3 or pm8
« Reply #1 on: September 13, 2009, 03:42:25 PM »
same head
« Reply #2 on: September 13, 2009, 04:21:21 PM »
same head, different cam/springs
« Reply #3 on: September 13, 2009, 06:09:26 PM »
Would you happen to know the details on the difference between the two?
« Reply #4 on: September 13, 2009, 07:29:03 PM »
One sucks, the other sucks hard.
« Reply #5 on: September 13, 2009, 08:53:45 PM »
One the cams, yes I know. I believe I measured the B1 cam, but it sucks.  B2 and B7 cams are the same.
SDRAWKCAB
  • D series BALLA!
  • Rhino
« Reply #6 on: September 13, 2009, 08:57:41 PM »
b7 has better springs.
« Reply #7 on: September 13, 2009, 08:58:19 PM »
You laid hands on a B2 with a B7 cam swapped in, then.  I went from a B2 with B7 IM and P06 to an actual B7, with the same exhaust manifold/exhaust/etc.  There's a difference in top end.
« Reply #8 on: September 13, 2009, 09:17:31 PM »
Nope, it was a B2 OEM cam, I still have it. 90 DX motor got sludged, supplied no oil to the cam and it seized. The car was serviced by local Honda and the head was replaced. I got the old B2 head. Still have the cam and head.
Made a great fixture.
About the B7 springs being better.....depends on when Honda changed oevr to use up old stock. 1992 and early 1993 production used D15 springs, but at some point in 1993 Honda started using D16A6 springs which are slightly stiffer.
turboblack2door
« Reply #9 on: September 14, 2009, 07:56:33 AM »
by looking at the head is there anyway to tell what springs? Also my b7head has threaded where the vtec solenoid   would bolt to like my a6 and the b2 doesnt
« Reply #10 on: September 14, 2009, 03:22:48 PM »
The d16a6 are painted type r red
« Reply #11 on: September 14, 2009, 03:36:21 PM »
That is for the fuel pump, not VTEC.
:duncecap:
turboblack2door
« Reply #12 on: September 14, 2009, 03:50:53 PM »
ok but its in the same place where the vtec solenoid goes
« Reply #13 on: September 14, 2009, 04:56:07 PM »
In jdm land some have carbs and mechanical fuel pumps that run off the cam.
« Reply #14 on: September 14, 2009, 05:11:10 PM »
put one there then sir.
