Author Topic: 94 ex clutch problem  (Read 11294 times)
« on: September 15, 2009, 11:24:47 PM »
Okay brothers clutch went out in his coupe. He bought a new one we put it in no prob. Took it for a test drive shifted smooth no prob. No it sat for a day started it up and the fucking this will not go into gear when running WTF! Never had this problem. When it's not runnin shifts fine I dunno wtf happen.
Re: 94 ex clutch problem
« Reply #1 on: September 15, 2009, 11:29:39 PM »
I bleed the shit out of it till all the fluid was new and still nothin
« Reply #2 on: September 15, 2009, 11:39:05 PM »
didn't let any air in. never removed the line
« Reply #3 on: September 15, 2009, 11:55:06 PM »
did you use a new throwout bearing?
« Reply #4 on: September 16, 2009, 06:35:48 PM »
yup new to,pilot bearings. I don't get why it wirked fine the first time and now nothing
« Reply #5 on: September 16, 2009, 06:48:58 PM »
You guys are proably goign to have to drop the transmission again something isnt right
Only thing it can be is the clutch assembly
« Reply #6 on: September 16, 2009, 09:11:13 PM »
I dunno what to try next now it is makin noise when clutch disengaged? I can push the slave all the way in when i crack the bleeder.  Tighten the bleeder and it works no prob until I let off the clutch and press it back in
« Reply #7 on: September 16, 2009, 09:49:53 PM »
Did you make sure the TB is locked on the clutch for properly, could be the tb bearing is jammed on the input shaft.
Either way you have to take the transmission back out. ;D
biscuit
  • 300HP D In the Works
« Reply #8 on: September 16, 2009, 10:10:05 PM »
+1
Sounds like an issue with the throwout bearing...
« Reply #9 on: September 16, 2009, 11:14:53 PM »
yup. it was the slave son of a bitch was stickin used the brake hone on it good to go
