Author Topic: cheap civic front brake upgrades  (Read 9846 times)
stealthiskey
« on: September 16, 2009, 06:53:33 PM »
I need to replace:
Master cylinder,
Front calipers,
Front pads,
Front rotors
Most immediately I need to replace the Master cylinder. Are there any cheap upgrades I can pick up readily at the parts store, like a larger MC from an integra or something? Or is this a stupid idea?
Re: cheap civic front brake upgrades
« Reply #1 on: September 16, 2009, 07:13:18 PM »
I need to replace:
Master cylinder,
Front calipers,
Front pads,
Front rotors
1" booster and m/c
stealthiskey
« Reply #2 on: September 16, 2009, 07:17:19 PM »
yea i found a couple links reccomending that, do I need to change the BB too or could i just use a 1" MC on my stock booster?
« Reply #3 on: September 16, 2009, 08:26:18 PM »
stealthiskey
« Reply #4 on: September 16, 2009, 11:16:52 PM »
Thanks for the link, good info:
Doing a bit more research it seems that the stock MC is 13/16"
The integra GSR or type R MC is 1", but the fitting for one brake line is located on the opposite side, and it will not bolt to the stock brake booster.
The 90-91 Civic MC is 15/16" has the lines in the right places, and should bolt to the stock brake booster.  The larger MC will give a stiffer pedal feel, which I think will be a good thing.  This looks like the one to get.
EDIT: turns out mine already has a 15/16" MC and it still sucks
« Last Edit: September 16, 2009, 11:25:17 PM by stealthiskey »
« Reply #5 on: September 16, 2009, 11:29:51 PM »
I have a 90 crx Si with a stock 15/16" mc and teg front rotors/hubs/calipers and and stock crx disks in the back. It will out brake my car. If I had some better tires on it Im sure it would make the brakes feel even better. The next upgrades to my brakes are gona be a set of good hawk or some kind of perfomance pads.
« Reply #6 on: September 17, 2009, 02:56:06 AM »
Cut a hole in the floor board fred flintstone style  O0 But really who needs breaks  ???
« Reply #7 on: September 17, 2009, 04:03:54 AM »
I have 3-4 pairs of 262mm (Teg) rotors left if needed.
spoonfedcrx
« Reply #8 on: September 21, 2009, 08:02:40 AM »
I had this exact setup.  Worked for me.
