Author Topic: fuel pump wont prime? ** problem solved **  (Read 10927 times)
lilpooh21186
« on: September 17, 2009, 07:30:57 PM »
So after my setup shit the bed i scored an ls motor. Now the swap has been in the car for a week now i cant get this bitch to start i get a solid cel. When the service conector is jumped same solid and i dont get any flash codes. with no ecu in there is no cel. I tryed new main relay's grounds chipped and stock ecu's im stumped i dont get a solid cel till the  last plug on ecu is connected. help me so i can sell this pos
« Last Edit: September 19, 2009, 06:15:02 PM by lilpooh21186 »
Ecu chipping
basmaps
realAgentMurdoc
Re: fuel pump wont prime?
« Reply #1 on: September 17, 2009, 08:41:44 PM »
i had a similar problem but I had no cels.
my problem was there was a break in the wire from the ecu to the main relay.  Sounds plausible since you say there is no cel til the last ecu plug is plugged in.
bust out a multimeter and check for continuity from the relay to the ecu and voltage.
lilpooh21186
« Reply #2 on: September 17, 2009, 09:03:39 PM »
ill have to pick up one of those
Ecu chipping
basmaps
« Reply #3 on: September 17, 2009, 10:24:53 PM »
grounds double check them
especially thermostat ground
DmC
« Reply #4 on: September 17, 2009, 11:18:00 PM »
what your explaining is a classic dohh I forgot the tstat housing ground.
« Reply #5 on: September 18, 2009, 07:06:22 AM »
I need a hug.
lilpooh21186
« Reply #6 on: September 18, 2009, 09:55:34 PM »
switched the tstat ground many times even connected it directly to battery negative no worky with it ungrounded there is no cel at all
Ecu chipping
basmaps
lilpooh21186
« Reply #7 on: September 19, 2009, 09:13:44 AM »
thats exactly what im saying while switching relays when the car is on i get the click so there getting some kind of power hopefully i can find a new harness for today and see what that does
Ecu chipping
basmaps
lilpooh21186
Re: fuel pump wont prime? ** problem solved **
« Reply #8 on: September 19, 2009, 06:18:47 PM »
Went out side this AM and it worked two times so i figured i have to check wiring b/c after cleaning up tools off the engine it wouldnt work.I started checking power and ground signals. Ecu power wire pin d1 was not getting proper power so a wire from the battery power to internal fuse box to the ecu fixed the prob .
Ecu chipping
basmaps
