Author Topic: HELP! no oil pressure  (Read 10364 times)
turboblack2door
« on: September 23, 2009, 09:04:57 PM »
i just put a b7 in my ef sedan and it had pressure for about a day now im not getting any. i  have checked the pickup tube and its clear checked the oil feed line and its nclear. I can blow air from the hole the sending unit goes in and if i block the oik channel from the block to the filter oil leaks from the squirters. is the pump bad or what
« Last Edit: September 25, 2009, 12:41:51 PM by AbaZ »
93 Honda Civic Del Sol -F22A6, H22 trans, Bisi rods, Aris pistons, Hondata S300, 1200cc RC injectors, e85, Koni Yellows, Ground Controls, fuck my expensive hobby
turboblack2door
Re: HELP! no oil pressure
« Reply #1 on: September 24, 2009, 11:02:04 AM »
nice input
« Reply #2 on: September 24, 2009, 11:04:08 AM »
Squirters?  Where are these squirters?
turboblack2door
« Reply #3 on: September 25, 2009, 08:12:38 AM »
fixed it was the pressure valve on the pump. works great now. thanks for all the ideas and
AbaZ
  • Out of retirement
    • R-HMT
« Reply #4 on: September 25, 2009, 12:41:32 PM »
Was the spring fucked up or what?
