Author Topic: rebuilt car doesnt start  (Read 13397 times)
« on: September 25, 2009, 09:33:41 PM »
lol.after all this its kinda funny.
ok, so i have about 40psi fuel pressure. im about the check for spark. the dizzy went in just fine, i did move the rotor dealie on the dizzy that goes into the cam so that the lines on it were all on the same side. fucking aye.
anything else i should check for other than spark?  :'(
Re: rebuilt car doesnt start
« Reply #1 on: September 25, 2009, 09:41:46 PM »
Uh, mechanical timing??? Just a theory.
« Reply #2 on: September 25, 2009, 09:48:37 PM »
timing is right, at least according to me. oil pump gear matched the mark, crank pulley matched its mark, and cam gears matched pointing up as well as the matching notches.
« Reply #3 on: September 25, 2009, 09:48:48 PM »
1342 firing order  check it
« Reply #4 on: September 25, 2009, 10:04:02 PM »
firing order is in check.
on the other hand its not firing. i has no spark. that was easier than i thought. ideas on that?
ill get to it tomorrow morning.
« Reply #5 on: September 25, 2009, 11:32:51 PM »
thermostat housing ground? but before that make sure the distributor is plugged in
Ghetto_D
« Reply #6 on: September 26, 2009, 12:49:46 AM »
call another meet...... and shave your dog this time.
check the fuses. and grounds. and connectors that go to the dist.
« Reply #7 on: September 26, 2009, 01:18:52 PM »
lol. damn dog hair is still everywhere.
« Reply #8 on: September 26, 2009, 03:50:12 PM »
crapped out dizzy. put on a spare i had, and she went on, for a glorious 2 seconds. i turned it off, bc my douchewaffle neighbor is blasting music, and i cant hear a damn thing.
« Reply #9 on: September 26, 2009, 05:59:07 PM »
its alive! lol. whoooo. i need to redo valves, as i hear them :-\
Ghetto_D
« Reply #10 on: September 27, 2009, 02:21:26 AM »
would that be those retro hits from the 80's?
« Reply #11 on: September 27, 2009, 02:46:56 AM »
lmfao. you know it. damn chilango.
« Reply #12 on: September 27, 2009, 10:29:04 PM »
 ;D
89shithatch
« Reply #13 on: September 28, 2009, 03:56:02 AM »
you put the pistons back in.
