Author Topic: 4.25 Final drive in cable dx trans?  (Read 15783 times)
bgdriver
« on: September 30, 2009, 07:25:07 PM »
So I have a si(pl3-9000) transmission that doesn't work and a dx(pl3-a100) transmission that does. I do not like the queer 3.8 FD. Can i take the si diff and final drive out put 35mm bearings on it and make it fit?
EDIT: or should i take the dx gear set and put it in the si case with the si FD?
« Last Edit: September 30, 2009, 07:58:50 PM by bgdriver »
1990 civic si
Turbo d16z6 going in.
Re: 4.25 Final drive in cable dx trans?
« Reply #1 on: September 30, 2009, 07:35:00 PM »
i would assume that would work fine.
but i will let bone come in here and do his thing.
« Reply #2 on: September 30, 2009, 07:43:29 PM »
main shaft
bgdriver
« Reply #3 on: September 30, 2009, 07:55:37 PM »
main shaft
What about it? will it not fit?
1990 civic si
« Reply #4 on: September 30, 2009, 07:59:56 PM »
how are you going to put 35mm bearings on a 40mm diff?
bgdriver
« Reply #5 on: September 30, 2009, 08:20:52 PM »
that's what i was thinking the problem would come in. the dimensions of the differential are different not just the bearings?
Will the A100 gearset fit into the si case with the si fd?
1990 civic si
lilpooh21186
« Reply #6 on: September 30, 2009, 11:14:18 PM »
where is mistabone?
Ecu chipping
basmaps
Ravage70
« Reply #7 on: October 01, 2009, 12:20:20 AM »
just run 5 more psi and forget about this nonsense
« Reply #8 on: October 01, 2009, 01:14:42 AM »
you'll have to swap the ring gear onto the small diff, then swap countershafts.
That means stripping them both and swapping JUST the countershaft.
« Reply #9 on: October 01, 2009, 06:41:19 AM »
i meant counter shaft in my earlier post
bone has spoken
« Reply #10 on: October 01, 2009, 06:56:31 AM »
only a 9.8% gearing advantage by changing the FD.......turn the boost up :)
deeznutts
« Reply #11 on: October 06, 2009, 10:45:31 PM »
so how diff are the gears between a dx and a si i have a dx and was going to buy a si but fuck if its not that big a diff the im not fucking with it..
fuck xeno
« Reply #12 on: October 07, 2009, 12:29:25 AM »
see post above yours.
deeznutts
« Reply #13 on: October 07, 2009, 05:38:37 PM »
well dx it is then hahah
fuck xeno
