Pages: 1 2 [3]   Go Down
Author Topic: Dohc Zc/D16a1 Fans. New Throttle Body adapter/Spacer  (Read 43007 times)
WOT
  • The Canadian
Re: Dohc Zc/D16a1 Fans. New Throttle Body adapter/Spacer
« Reply #60 on: December 02, 2009, 01:51:24 AM »
Oh my head isnt stock lol, gasket matched and ported, crane cam, oversized valves etc etc, just have a stock overbored T/b. Which I plan on upgrading
You also sell t/b's?? If the stock cable works Id def be up for upgrading, that billet spacer looks tits
« Reply #61 on: December 02, 2009, 04:56:32 AM »
Dump the d16a6 manifold and upgrade to a ported d16z6 manifold. I also make a spacer for that manifold so it can hold one of our big bore throttle bodies 74mm inlet-68mm plate or 70mm inlet-68mm plate.
http://www.realhomemadeturbo.com/forum/index.php?topic=4054.0
http://www.realhomemadeturbo.com/forum/index.php?topic=5009.0
« Reply #62 on: December 19, 2009, 07:24:23 PM »
Zc powa
arsenio
« Reply #63 on: December 20, 2009, 02:16:27 AM »
so does this space use the stock bolt pattern or a different one?
Will you miss me?
« Reply #64 on: December 20, 2009, 03:40:53 AM »
ZC
« Reply #65 on: December 20, 2009, 07:11:46 AM »
b series pattern on zc manifold
arsenio
« Reply #66 on: December 20, 2009, 04:30:51 PM »
Yeah. I know its for a zc but what is the NEW  bolt pattern for the throttle body?
Also, I have a buddy with a dohc zc realtime wagon. When it starts up, blue smoke comes out. What could that be?
Will you miss me?
« Reply #67 on: December 20, 2009, 04:48:41 PM »
Blue is rings or seals.
« Reply #68 on: December 20, 2009, 05:00:41 PM »
throttle body bolt pattern is
aftermarket or b series
« Reply #69 on: February 02, 2010, 01:46:21 AM »
d16a1 head is at the machine shop for the valve job. Super duper ports
90turboteg
  • Rebuildin turbos
« Reply #70 on: February 02, 2010, 01:47:29 AM »
when are you gona have time to do my head :-*
« Reply #71 on: February 02, 2010, 01:48:24 AM »
Soon I have a couple more k series/s2000 things to finish up first.
90turboteg
  • Rebuildin turbos
« Reply #72 on: February 02, 2010, 01:50:18 AM »
sounds good. id like to get my big ported head on with the delta 272s, supertech springs/retainers, your 74mm tb and spacer and see what kind of #s i can put down with the vitaras. 1g crx ftw. stock valves should work alright huh?
trevor72
  • trevwhore
« Reply #73 on: February 02, 2010, 06:53:06 PM »
Your new cnc mill technician looks like she does good work  :P
also this thread revives my desire to build a 1G rex!!! Thanks
« Reply #74 on: February 04, 2010, 08:30:00 PM »
Today is k series porting fun. Ill post some pics here tonight. Oh yeah!
90turboteg
  • Rebuildin turbos
« Reply #75 on: February 05, 2010, 12:31:13 AM »
in for the pics nog
« Reply #76 on: February 05, 2010, 02:30:54 AM »
« Reply #77 on: February 05, 2010, 02:44:13 AM »
Looks great!!
90turboteg
  • Rebuildin turbos
« Reply #78 on: February 05, 2010, 04:47:57 AM »
jebus. i hate you. now make my head look like that :P
« Reply #79 on: February 05, 2010, 03:03:29 PM »
Thats the plan. Working on my h23a bluetop vtec head a little this weekend
« Reply #80 on: April 22, 2010, 05:50:06 AM »
Still working on the bastard d16a1 build that is about the 48th thing to do on the list. Have a set of cams going off to delta this week.
« Reply #81 on: April 22, 2010, 08:23:19 AM »
Use LS valves to get another 0.010" stem height above the keeper, tell Delta to grind it wilder as geometry isn't stock anymore.
« Reply #82 on: July 08, 2010, 06:05:28 AM »
Head is done needs another bath thing is still dirty after 3 power wash duties and I need to figure out what valve springs Im going to run in this bastard. Also having a dog eater aka Mr. Phan hook it ups on an obx lsd for the transmission.
I also gutted the 25 year old interior. I should have it up and running by 2016.
« Reply #83 on: July 08, 2010, 06:11:30 AM »
Oh and Im getting rich off the zc adpater/spacer I have sold a total of 3 of them :'(
« Reply #84 on: November 09, 2011, 04:59:48 PM »
zc
Pages: 1 2 [3]   Go Up
