Author Topic: RHMV: thinking about building a vaporizer  (Read 7650 times)
darksol2005
« on: October 29, 2009, 04:15:18 PM »
I've had the idea of doing this for the past couple days.  It's a fairly simple design.  Heating element, box/container for "tobacco", and tube.  I'm thinking I could actually make something decently nice too, instead of paying 100+ bills for one.  Just curious if anyone has any input or pics of what legit ones are using on the inside of em
Re: RHMV: thinking about building a vaporizer
« Reply #1 on: October 29, 2009, 04:20:53 PM »
go vaporize your face
darksol2005
« Reply #2 on: October 29, 2009, 04:23:47 PM »
Angry much?
« Reply #3 on: October 29, 2009, 04:26:39 PM »
Your avatar require a login from performance-dont-know-what. Remove that shit.
« Reply #4 on: October 29, 2009, 04:42:17 PM »
when i built mine for the boba costume... i used
1 soldering iron with a stainless steel spoon screwed into the iron(i cut off the handle because it just would not fit in the jar),  a dimmer switch because the iron on full blast will approach the "tobacco's" ignition temperature.  then i just contained it with a glass jar and piece of wood that the iron was fixed to. i used a broken nebulizer air pump to blow the "tobacco smoke" into the helmet.  i mean i didnt want to get light headed from the oxygen, fuck that.  hook it up to a nice size battery and your mobile. or use the wall socket with the dimmer and booya grandma
« Reply #5 on: October 29, 2009, 04:50:05 PM »
i will sell you mine for 50.00 plus shipping its a hot box brand i paid 200.00 for it pm me
darksol2005
« Reply #6 on: October 29, 2009, 06:38:48 PM »
Not a bad idea....  Only thing I need to know now is, do you NEED to have some kind of pump incorporated as well?
« Reply #7 on: October 29, 2009, 07:02:21 PM »
i seen a nice write up on this when searching google back when i smoked. kinda the same idea that was stated above with the dimmer switch and soldering iron but they used a mellon baller thing with the hole already in it and its deeper then a normal spoon. looked pretty simple to make, i just decided to not smoke weed anymore so i didnt make one
« Reply #8 on: October 29, 2009, 07:47:15 PM »
i guess buying a 200dollar vaporizer for 50 dollars would be to easy...then you wouldnt have to make a thread about making one though
darksol2005
« Reply #9 on: October 29, 2009, 08:47:33 PM »
Are you that much of a broke crackhead that you have to slang your belongings on forums? Thanks for the offer, but I'll pass
« Reply #10 on: October 29, 2009, 10:04:40 PM »
no, you dont NEED the pump,  oh, and make sure you use a new soldering iron, because you dont want to inhale that other shit you would use an iron for.
bryantaylor
« Reply #11 on: October 30, 2009, 12:51:35 AM »
90 miata - t3 and megasquirt
95 mark VIII
06 GSX-R 600
 i changed my sig as per Robb
« Reply #12 on: October 30, 2009, 10:52:02 AM »
Never liked em.
« Reply #13 on: October 30, 2009, 02:01:57 PM »
step one: take glass light bulb, clear one,  not a white one
step two: smash off the metal part so you have a bulb
step three: put weed in glass light bulb and get lighter and glass shards
step four: use glass shards to cut wrists and lighter to burn down house
=profit
« Reply #14 on: October 30, 2009, 02:09:27 PM »
well duh after buying my 2005gsxr,new turbo,material for new turbo manifold,rent,plus im married fuk yeah im broke so where do you want me to ship this vaporizer to?
« Reply #15 on: October 30, 2009, 02:45:44 PM »
The thought of seeing your fatass on a bike is hilarious.
