Author Topic: dizzy help JD??  (Read 11275 times)
1fasthf
  • RHMT resident Bruce Buffer
dizzy help JD??
« on: October 31, 2009, 09:55:51 PM »
Well guys after JD helpin me figure out my slow crank problem, which was my bad grounds, I just got my dizzy on and I'm not receiving spark. I busted out the multimeter and I'm getting 12v to the little plug but can't find a wire with 12v on the larger plug!! Is this normal?? Or am I not gettin volts to the dizzy?  I appreciate all the help newb nudes are comin I promise
Re: dizzy help JD??
« Reply #1 on: November 01, 2009, 09:05:45 AM »
That's correct, with KOEO (Key On Engine Off).  When cranking/running you should see pulses on the blu/yel wire which you probably can't see with a normal meter.
90% likely you have a bad coil/ignitor, OR the distributor is miswired.  You can have the distributor wired wrong and it will usually spark on some level, whether popping during cranking or just not running well with or without CELs.
1fasthf
Re: dizzy help JD??
« Reply #2 on: November 01, 2009, 01:32:56 PM »
Ok so I am receiving power to the dizzy ... I'm running out to do an ohm test on the coil
1fasthf
Re: dizzy help JD??
« Reply #3 on: November 01, 2009, 01:41:42 PM »
Ok I'm getting .8 on the pos and neg terminals then from positive to the spring I get 17.25. From what I've read that's close to spec right?? Is there a test for the ICM??
Re: dizzy help JD??
« Reply #4 on: November 01, 2009, 01:43:40 PM »
Not with the tools you have on hjand, without possibly frying the coil.
1fasthf
Re: dizzy help JD??
« Reply #5 on: November 01, 2009, 04:24:45 PM »
YES got spark ended up being the yellow/black wire wasn't making a good connection in the connector. Now I gotta drain the oil (smells like gas) and put in some fresh fuel and see if I can get this bitch started
1fasthf
Re: dizzy help JD??
« Reply #6 on: November 01, 2009, 09:48:02 PM »
Fuck My Life... I drain oil to remove the pan to install my drainline and I find copperish shavings I'm guessing bearing shavings. So I'm gonna pull the caps tommorow to see what damage is done
