Pages: 1 ... 6 7 [8] 9 10   Go Down
Author Topic: My D16z6 w/ SC14 Supercharger. Pg 6 Twinchared  (Read 366844 times)
Re: My D16z6 w/ SC14 Supercharger. Pg 6 Nose job on the CX
« Reply #210 on: April 27, 2012, 09:55:36 AM »
I just hope its not blown up inthe next 2 weeks
I think it will get babied all the way up there, raped a bit on the dyno then babied on the way back.  :noel:
Eggylshatch
  • Pen15 Club President
« Reply #211 on: April 27, 2012, 02:37:03 PM »
So the supercharger is going to blow into the turbo, with some sort of bypass for when the turbo is doing more sucking than the supercharger is blowing?  Or?  And do you have enough room for both, and took plumb it all together?  That turbo is fucking enormous.
« Reply #212 on: April 27, 2012, 02:51:06 PM »
Turbo => S/C => inter cooler => TB => engine
There will be a by pass around the S/C when the s/c clutch is disengaged.
The compressor wheel size of the HE351ve is very similar in size to the HX40 at 60mm inducer 80mm exducer.
The turbine housing is just freakin' hugh due to the use VGT, which basically acts as means to "A" in A/R of turbine side.
A/R of like .5 to 1.1 is roughly what it be like.
I'll start at the largest A/R and work my way up to what I want for my goals.
« Reply #213 on: April 28, 2012, 11:50:47 AM »
I wouldn't recommend using the SC clutch except to save a cunthair more gas while cruising. The clutch will not like constantly engaging with a 20-30hp load on it instantly if you work it at WOT. When bypassed, the SC is just moving air; almost no power is used to turn it.
I honestly think the only reason MB uses a clutch is for that extra bit of gas savings to attain better emissions.
« Reply #214 on: April 28, 2012, 11:57:18 AM »
And to improve thermal efficiency due to air recirculating between lobes and casing wall.  :noel:
« Reply #215 on: April 30, 2012, 12:17:44 AM »
Alright I have turbo on with the radiator support clearance and the hood barely shuts.  :noel:
To get the He351ve to fit, I had to cut the mounting ear on the S/C not being used.
Ground for clearance
More grounding for clearance
Had to replace the mounting studs
Lucky I had this coupler going from 2.5" to 3.0 90deg, had to shorten it on the turbo side.
This where I'm at until tomorrow :noel:
Already ran the oil drain, not pictured here.
Next I'll work on the radiator and ducting setup.
Then finish 3" exhaust from turbo to resonator.
Ordered a turbo blanket and 50' of 1" wide header wrap, should see that this week.  :noel:
« Reply #216 on: April 30, 2012, 12:32:12 AM »
I bet grinding that off the housing took forever.
Looking good, what cylinder rod bearing you plan on spinning this year? :P :P
Nice work
« Reply #217 on: April 30, 2012, 12:32:58 AM »
Nice work
King bearing with new Cunningham rods  :noel:
« Reply #218 on: April 30, 2012, 12:33:35 AM »
You check the clearances on those bearings??
« Reply #219 on: April 30, 2012, 12:54:20 AM »
$5 says you warped the turbo housing with the grinding heat. ;DDD Fuck that must have been either a big grinder, or one that's now burnt out.
« Reply #220 on: April 30, 2012, 07:24:20 AM »
If ya talking about the turbine housing, I used an industrial grinding wheel at the foundry I work at.  :noel:
« Reply #221 on: April 30, 2012, 09:00:31 AM »
Well, make sure you put your header in the trunk along will all your tools when your making the trek up to the dyno day. That way when you hit Montana and something shits itself You can at least put it on and drive it na. Other than that how are you going to control the vgt?
« Reply #222 on: April 30, 2012, 09:15:54 AM »
Russ solid work!
« Reply #223 on: April 30, 2012, 11:10:38 AM »
I'll have two tabs with bolts to adjust to one setting, or a range.  :noel:
Cover that in the next couple days.  :noel:
« Reply #224 on: April 30, 2012, 07:24:14 PM »
« Reply #225 on: April 30, 2012, 08:12:32 PM »
Yes they checkout, towards the loose side.  :noel:
JaredKaragen
« Reply #226 on: April 30, 2012, 09:59:18 PM »
If you have the VGT solenoid it is possible to hook a EBC output up to control it :)
You'd just need to finagle the settings to make it work properly.
I plan on trying to use my egr as a wastegate this way... We will see how that goes.
« Reply #227 on: April 30, 2012, 10:04:05 PM »
I did not a solenoid.  :noel:
« Reply #228 on: April 30, 2012, 10:22:27 PM »
the whole thing?  wow
« Reply #229 on: April 30, 2012, 10:34:47 PM »
LOL my proof reading sux.  ;DDD
« Reply #230 on: May 01, 2012, 12:11:55 AM »
no one has faith in russ. This year you have nothin I need weird.
« Reply #231 on: May 01, 2012, 04:05:20 AM »
I have faith in Russ. HEs got heart.
« Reply #232 on: May 01, 2012, 09:57:45 AM »
Oh I have faith that Russ will make it run, maybe not well, but it will run.  O0
Where is the wastegate going?
« Reply #233 on: May 01, 2012, 10:02:30 AM »
Russ just kills himself by doing too much at once. It's always something small that ends up being impossible to track down since he has 14 unusual things added each step...
Russ get one thing working at a time and you'll be good.
« Reply #234 on: May 01, 2012, 11:08:14 AM »
No WG going with adjusting the VGT to full open.
Then adjust when needed.  :noel:
« Reply #235 on: May 01, 2012, 06:18:27 PM »
It WILL still overboost even with the vanes wide open. I promise this as we have already tried this with a vitara D and this turbo. You still need a wg to control overall boost pressure. With the vanes wide open it was slow to spool, but would still make 30psi+
« Reply #236 on: May 01, 2012, 07:02:53 PM »
I found one of the exhaust bolts and springs daspoop littered my driveway with still in my front yard yesterday doing his hack of an exhaust in my driveway.
« Reply #237 on: May 01, 2012, 08:48:44 PM »
LOL I remember that. :noel:
« Reply #238 on: May 01, 2012, 11:28:01 PM »
Alright I'd follow your advise and pull the manifold turbo off and get the 50mm WG added on top of the mani, with a 90deg bend.
I already took the radiator support back out and unbolt everything, got to bring it to work b/c I do not have the means to put a hole in the mani.  :noel:
« Reply #239 on: May 01, 2012, 11:42:44 PM »
+ WG
Pages: 1 ... 6 7 [8] 9 10   Go Up
