Author Topic: 800+HP street S2000  (Read 24258 times)
Re: 800+HP street S2000
« Reply #30 on: December 01, 2009, 01:27:16 AM »
i went 124mph........ does that mean I can play with the big boys?
gringotegra
  • Smoking Bisimoto's Builds, 1 Car At A Time
  • BISIMOTO KILLER!!!!!!!
« Reply #31 on: December 01, 2009, 02:07:13 AM »
that means you should be pretty even with a stock C6 Z06
« Reply #32 on: December 01, 2009, 03:51:41 AM »
Ok. I'll make sure I find some stock Z06's so I can race them and be side by side
at 66.66% throttle
« Reply #33 on: December 01, 2009, 06:47:07 AM »
Miles... Seriously.... We dont need a lesson on how shit works. Levis car would WAX a zo6 ... with him letting off at 3/4 track.
Jeremys would not.
« Reply #34 on: December 01, 2009, 10:03:01 AM »
So, back on the semi-original topic of big power stock engine S2000 in hopes of actually having some tech in a shithole thread where Spiker mouths opinions on Jeremy because he can't deal with the real world.  I was sitting around with some friends last night and we were pondering if the big power stock motor thing was going to be another short term fad.  A perfect analogy for this would be the evolution of knowledge on B-series sleeves.
In the bad old days it was common knowledge that past 400 whp you really needed to sleeve your block.  This was based off of zero perspective paranoia.  Then suddenly a couple kids with a fuck it attitude made 650+ on stock sleeves, and in a very short time a lot of people did so as well and the common knowledge became stock sleeves are good for 650+.  Fast forward another few years and 20/20 hindsight says these motors came apart quick and you really need sleeves past 400 whp.
F20C is a super stout motor, obviously, but I'm wondering if it's going to be a similar situation where in a couple years people look back on big power stock motors as a really bad idea?  Stock cast or hyper pistons are always fragile, and there is a meme of people putting forgings on stock rods.  Well, as an engine builder buddy of mine pointed out, this is also a problem. Nothing against the stock rod as it's obviously strong, but stock pressed fit pins are good for low horsepower high mileage OEM applications.  There is a reason why the aftermarket universally embraces full floating pins as there is less friction.
Keep in mind that when I say this, it takes a lot less motors popping than in the B, D, or K worlds for it to have a grave impact on the S2000 scene as there are only so many F2xC.  What do you do when you run out of them, start swapping in 2JZ like a knuckle dragging JDM redneck?   :-\
« Reply #35 on: December 01, 2009, 10:34:05 AM »
Are you referring to the stock pistons being cast? Unless i missed it somewhere s2000's have forged pistons and based on viewing my pistons out of my f20c i fucked up they look just like any other aftermarket piston, they even have a coating on the skirt. there also full floating.
but i do think that most s2000 people will keep it pretty tame as far as power levels. It's the shops out to prove something that make "stock block" power. really most people stop at around 400-450 whp.
« Reply #36 on: December 01, 2009, 10:40:38 AM »
No shit?  I stand corrected.
speedjunky01
« Reply #37 on: December 01, 2009, 11:21:02 AM »
When you had yours apart did you look at the rods?  In your opinion how "beefy" are they?
look damn thick to me, dont know if he measured ect im ASSuming
http://video.google.com/videoplay?docid=-2842254698128575108&ei=FjQVS42GOcfdlQf72by0Dg&q=s2000+motor&hl=en&view=2&client=firefox-a#
« Reply #38 on: December 01, 2009, 11:28:16 AM »
Dude, never assume anything from faggots who make CG videos of an engine being built.  They are the reason ASE fucking fails.
Google search took like 2 seconds.
Stock rod next to a stroker rod.
And its even some from fucking faggot magizine article. There you go.
speedjunky01
« Reply #39 on: December 01, 2009, 12:15:07 PM »
« Reply #40 on: December 01, 2009, 01:14:00 PM »
If you guys want detailed pic of the engine it is sitting in a million pieces. can see some nice valve carnage.
« Reply #41 on: December 01, 2009, 01:22:42 PM »
Lots of Z06's trapping anywhere from 128 to 132.
Look up ranger Z06 .. 10.8's in a stock car on DR's
« Reply #42 on: December 01, 2009, 01:54:30 PM »
Please?
« Reply #43 on: December 01, 2009, 01:59:56 PM »
will do
« Reply #44 on: December 01, 2009, 02:04:29 PM »
I'm from Fargo,Nd and i have not a clue about a engine being sold. sorry
« Reply #45 on: December 01, 2009, 02:28:20 PM »
JD EVERYONE is aware that you are a faggot, no need to proveit time and time again.  :-*
« Reply #46 on: December 01, 2009, 02:50:27 PM »
I'm not a faggot so much as a chubby chaser... and I've yet to meet a woman as voluptuous as you, Brian.   :-*
« Reply #47 on: December 01, 2009, 04:29:22 PM »
Thats because your busy chasing men.  LIttle 13 year old ones at that.   :-* :-*
« Reply #48 on: December 01, 2009, 04:53:35 PM »
gringotegra
« Reply #49 on: December 01, 2009, 08:00:44 PM »
Bone stock id say the 90% out there trap 123-126 and run 11.50-11.20's... my roomates 07 Z06 off the show room floor it was trapping 124 and went 11.31...best mph it ever saw was 127 on a cold ass 40 deg night...now that car has intake, long tubes, cam and a E85 tune makes 556whp  traps 132-134 on average and its a beast on the street..
« Reply #50 on: December 01, 2009, 09:21:27 PM »
3150 without driver....
550 whp..
mid 130 traps???
« Last Edit: December 01, 2009, 09:24:03 PM by bigdaddyvtec »
gringotegra
« Reply #51 on: December 01, 2009, 10:02:47 PM »
550 whp..
mid 130 traps???
we weighed his and it was more like 3200 with driver on the same scale my car was 2650 with driver and full interior.. ive been trying to get him to go to seattle  ;D... Spiker  its the same guy that bought the 4 door!! i got some timeslips here of his car trapping 132-133..The car traps 102-105 in the 1/8th..
Corection roomate said it was 3100lbs
« Last Edit: December 01, 2009, 10:06:22 PM by gringotegra »
« Reply #52 on: December 02, 2009, 03:28:08 AM »
I am down to race his Z06. Set it up
I also still want a supra................... I have needs
« Last Edit: December 02, 2009, 03:42:53 AM by Urban Indian »
« Reply #53 on: December 02, 2009, 07:04:35 AM »
ZING with our arguements in updated posts  :-*
slappynuts
« Reply #54 on: December 02, 2009, 08:35:33 AM »
Wait till fernando puts on his new kit  ;)
gringotegra
« Reply #55 on: December 02, 2009, 11:32:07 AM »
It would have to be down here... hes too big of a puss to drive up to seattle just to race someone...and without knowing what he is racing he wont go...ive tried to get him to go many places but theres that fear of him possibly loosing a race that he doesnt like...if he ever goes to race someone with a really fast car he always talks about how he will just go throw on a 150shot and itll be all over... kind of pisses me off that he cant just go race somone for shits..
88crex
« Reply #56 on: December 03, 2009, 06:34:08 PM »
myles you fucking e-race more than anyone i know. Only other dumbfuck i hear talkin trap speed this and trap speed that is the fucking homo chris from clutchmaster's i think you have talked to him too much.
