Author Topic: Zeniceguy Big boost D16a1/MACK turbo  (Read 94611 times)
Zeniceguycrx
Re: Zeniceguy Big boost D16a1/MACK turbo
« Reply #31 on: March 25, 2009, 09:17:15 PM »
at what psi?
The 30psi king of rice
kamilk69
« Reply #32 on: March 25, 2009, 09:19:53 PM »
100000000psi
Zeniceguycrx
« Reply #33 on: March 26, 2009, 12:19:09 PM »
so if I do 20000000000000 its good till forever HP?
7808
« Reply #34 on: March 27, 2009, 10:43:56 AM »
You know the best looking crx's are the ones all JDM'd not the ones with stupid looking body kits and Z3 fenders, take all that stuff off and get all jdm stuff and loose the SS Auto Chrome header there junk and get a log mani.
i thought talk like this is supposed to get you banned instantly...  at least it would if i had a say in it  youd be out of here fagot
ss autochrome > jdm
« Reply #35 on: March 27, 2009, 04:18:13 PM »
any time you smoke an engine there is a vwery good chance you got metel fileings in the oil befor it went.  Metel fileing on a bearing spinning @ 100,000 rpm = weak souce.
Only if you're dumb enough to use a sandwich adapter that uses the unfiltered oil. Given your taste in CDM parts, I'd guess that was the case.
I've never seen a motor blow up and get to the point of opening the filter's bypass. In all cases the pickup gets stuck with shit, and the motor stops fast enough. In short, the only thing that will kill a turbo internally is feeding it unfiltered oil, or not enough oil.
BTW this thread is a clusterfuck of fail. Mostly on the part of the 'peanut gallery', not the OP himself. >:(
caged
« Reply #36 on: March 27, 2009, 05:41:24 PM »
That sticker is fucken tits :noel:
« Reply #37 on: March 27, 2009, 06:29:49 PM »
drive that ugly piece of shit off a cliff
Zeniceguycrx
« Reply #38 on: March 27, 2009, 08:07:17 PM »
turbo was direct feed from the oil switch location.
AstroVannin
« Reply #39 on: March 28, 2009, 12:28:33 PM »
Looking forward to seeing this thing at the track this year.
You ever do Mosport or Shannonville with it?
