Intro :- I'm a student , i'm broke, and i wanna make my car faster
The car . 1989 toyota levin with a mongrel 4agze in it. Started off like this with a redtop high comp 4age
4age with sc12 s/c at 9 psi, 10:6:1 c/r, tmic no hood scoop.
Blew the head gasket the same day took it home from my friends home due to a busted radiator. Rebuilt with forged oem 4agze 8:9:1 pistons and semimetal gasket.
Cut the hood with a grinder to make a scoop and took the car to the track on dec 6th Run a 18.0 with a massive boost leak, only had 3psi , and all season tires. That was the last sraw with the s/c. took it off as soon as i got home and started turbo conversion.
1st manifold attempt
turbo hit oil filter and mount when mounted in car so i scrapped it and went to work on this
free t28
manifold on prop block and head
still need to port manifold run oil lines and piping.
