Author Topic: bushings suck...  (Read 9351 times)
michigan_soler
bushings suck...
« on: October 09, 2010, 11:19:39 AM »
Like the title says... pushingout bushings from a 20 yocar sucks.... probably cuz its from Michigan....
Re: bushings suck...
« Reply #1 on: October 09, 2010, 11:21:09 AM »
Just have to know how to deal with them.
 ;D
michigan_soler
« Reply #2 on: October 09, 2010, 01:15:57 PM »
My craftsman sockets don't fit right in my 20 ton HF press.... also its my first try.  Any good tricks?
« Reply #3 on: October 09, 2010, 01:20:15 PM »
Burn them out with a torch. Then you can press out the sleeves
« Reply #4 on: October 09, 2010, 02:35:15 PM »
Burn them out with a torch. Then you can use a sawzall to relief cut the sleeves
« Reply #5 on: October 09, 2010, 03:21:00 PM »
« Reply #6 on: October 09, 2010, 03:44:23 PM »
Torch to burn it, zip gun to get the sleeve out. 10 minutes and you're done.
michigan_soler
« Reply #7 on: October 09, 2010, 04:11:05 PM »
I was pushing the bushing out. Then saw the sleeve then hammer
michigan_soler
« Reply #8 on: October 09, 2010, 04:12:44 PM »
Also al my sockets are the wrong size...
michigan_soler
« Reply #9 on: October 09, 2010, 04:16:15 PM »
Maybe I'm outta the loop but isn't a zip gun like a handgun of some kind?
rawr2d2
« Reply #10 on: October 09, 2010, 04:18:09 PM »
I used to use a chisel or something on the sleeve and whatever the sleeve was in after you take it out the sleeve just falls out.
michigan_soler
« Reply #11 on: October 09, 2010, 04:37:15 PM »
I'm guessing I'm just shitty at life....  I'm gunna try to build some sorta press punch to fit and push it all out at once.....  outta black pipe and using a finder, file, and drill to spin it... haha
rawr2d2
« Reply #12 on: October 09, 2010, 04:43:45 PM »
You need fire. If you dont have a torch just build a camp fire and throw those fuckers in.
michigan_soler
« Reply #13 on: October 09, 2010, 05:01:28 PM »
I have a baybay propane one and a few tanks of map gas. Usually only for freeing seized bolts but ill try tonight..
« Reply #14 on: October 09, 2010, 05:16:09 PM »
Zip gun. Maybe there's another name for it like hammer gun or something like that
« Reply #15 on: October 09, 2010, 05:45:23 PM »
Air chisel with a panel cutting bit...or a sawzall.
« Reply #16 on: October 09, 2010, 05:55:20 PM »
I got a trash fire going when I did my front LCA bushings.
« Reply #17 on: October 09, 2010, 06:00:26 PM »
Those of us who don't have a French background call that an air hammer.
Yes it works well for driving the shells out once you have made a relief cut in the shell.
michigan_soler
« Reply #18 on: October 09, 2010, 06:59:27 PM »
I didn't even think of an air chisel.... I was doing chisel with hammer
« Reply #19 on: October 09, 2010, 07:14:05 PM »
I burn then cut. Hacksaw re-assembled with the blade inside the hole. I almost had a disaster using a sawzall once, so now I shy away from powertools when it comes to iron suspension parts.
« Reply #20 on: October 09, 2010, 07:24:52 PM »
Get a little carried away did ya?
 :P
michigan_soler
« Reply #21 on: October 09, 2010, 09:10:55 PM »
Has anyone on here put zirc fittings on lcas?
Just currious how they work...
« Reply #22 on: October 09, 2010, 09:12:51 PM »
No, but I probably should so that I can keep the poly bullshit lubed.
I think that the bushings should be grooved on the ID as well as the OD with a passage in between for ti to work worth a damn though.
Jordy53
« Reply #23 on: October 10, 2010, 10:20:31 AM »
I put some of mine in the oven first and then pressed them. They slid out like butter. All I used was snapon sockets and some sheet metal to make them sit level in my press.
You cannot help the poor by destroying the rich. You cannot strengthen the weak by weakening the strong. You cannot build character and courage by taking away men'#39#39s initiative and independence. You cannot help men permanently by doing for them what they could and should do for themselves.
michigan_soler
« Reply #24 on: October 10, 2010, 04:05:22 PM »
I'd have to say my biggest problem is not having the right size sockets...
« Reply #25 on: October 11, 2010, 12:06:14 AM »
I'd say your problem is not starting a god damn fire like you've been told to do.
« Reply #26 on: October 11, 2010, 12:08:52 AM »
Socket is useless, use a
ZIP GUN
« Reply #27 on: October 11, 2010, 12:13:26 AM »
ZIP GUN
 ;D
michigan_soler
« Reply #28 on: October 11, 2010, 12:16:28 AM »
I fired the rest of them.... I mean to easily press out the sleeve instead of the saw....
« Reply #29 on: October 11, 2010, 12:21:38 AM »
Burn out and then use the ZIP GUN  :P
