So I guess this is the new HMT home now, huh? Well, here's my build again...
First off, I'm from norway, so my english sucks
Second, I'm not cornfuzed, that guy from the old site that everyone seemed to hate
I was lurking on the old forum since feb 06 and tried to suck up as much info as I needed to put my own turbo system together. I didnt know shit about turbo's or cars before I found this site, so this is my first turbo setup and motor build, but definately not the last. I really enjoy the idea of getting boosted for less than the price of a b-series header and be faster 0O
Anyway, here's some eyecandy:
Then onto my first turbo setup:
D16Z6, rebuilt with stock stuff
t3.42/.48
FMIC, backdoored
Homemade mani, charge pipes and dp
eGay bov, clamps and couplers
Something weird on the dyno. Had to pull way more timing than what I've seen others do. Tuned with crome free + freelog
Went to the circuit, and here's the result... Dont know if it was because I had hit the ground a couple of times with the dp, too high egt because of all the timing I had to pull, poor welding or just too thin walls on the mani... Some bracing action...
So I bought ectune, already had a wb, made some detcans and went for it. Havent tried tuning myself before, so it was fun :p I'm still not sure on what knock sounds like, lol.
Some vids from the circuit:
So the stock block actually survived the season, I'd never would have thought that. I'll be using the block for some vitara's and fjt's custom i-beams this winter
Fartcan is gone, had to route the dumptube into the exhaust to pass inspections at the track. Also got a new turbo, a 46 trim t4/t04e with a small .48 a/r exhaust side. Hopefully it'll spool about as fast as the saab turbo, without the choking on top.
Had to bring out the welder again... Ext wg this time.
Fatty welds ftw
Vitara's next
Doesnt hav a engine hoist, but I borrowed this for free :somb:
Pistons and rods
Went for a 0,08mm p2w clearance, or 0.003-0.0035" ... Going for max 300whp
Notching... Tried to mark it, but ended up eyeballing it... Hope its big enough.
Gapping the rings... Boring!
Cheapie ring compressor. :somb:
Checking the clearances. Came out a bit loose. Thats a good thing for this use I suppose...?
Ported a little bit in the oil pump. I reused my old oil pump so didnt feel like filling the blind entrance behind the hex plug with epoxy.
Made some new oil lines. I'm sick of dealing with sensors behing the block, so I made this. Much easier
Hydraulic hoses from work = free :somb:
Mfactory lsd going in too. Never even opened a gearbox before, so I had to use the helms manual a lot :p
Motor coming home. Still snowing outside. Fuck
Oil cooler was a pain in the ass. Had to move the radiator to make room for the fittings. So I have like 1mm left before it hits the dp.
The car
Homemade sticker :1 Edit: I guess I have to dig up the tape and add an R now.
I HATE SNOW! Just waiting for the spring now... At least with the lsd I'm not getting stuck. Car seems to work fine, a little diesel'ish sound but I guess thats normal. I warmed it up and raped it pretty hard for the rings to seat, I'll just have to put some miles on it now before I take it to the tuner...
Edit:
So I editet my whole post now. Hope you're happy RICK P
