Author Topic: silicone charge pipe/ coupler- half failure  (Read 9560 times)
oinesra
« on: November 10, 2009, 05:19:45 PM »
everyplace online sells 2" 90 degree silicone couplers for 16 bucks. fuck that. plus what i need is a set of 90s in series. so i decided to make some. after i had already 'made' this one, i started having better ideas, so this basically was a good learning process.
went to harbor freight and picked up some self-fusing silicone tape on sale foe 1.17 each. its rated up to 500 degrees.
got some plastic bags to make a mold  from.
this is what i want to make from silicone
making the mold,. this is about the time i realized i should have got some foam rings from walmart. fuck it, keep going
finished the bitch up with a scrap of silicone coupler on one end and coated with wax for easy removal.
i fucked up and some how erased all the pics of winding this bitch up. but i laied down 3 rolls, and ended up warping half to tight, so it was like 1.5 inch inside diameter. i trimmed it down and jammed the pink 90 into the thing. wrapped the silicone part in a few coils made of a wire coat hanger. then laied down the other rolls of silicone over it.
pulled the plug
fit like a charm.
not bad for 20 mins of work, and if i had got the foam rings i could have had perfectly round tubes. i will redo this one day, and i might just do all the charge pipe in silicone with either metal coils like this one, or do the core of the coupler with liquid silicone and fiberglass tape.
here is the extra that i fucked up.
oinesra
Re: silicone charge pipe/ coupler- half failure
« Reply #1 on: November 10, 2009, 05:34:13 PM »
it SHOULD be able to. the silicone part is about 1/4 inch thich and ribbed with coat hanger coils. but i will find out soon enough.
« Reply #2 on: November 10, 2009, 05:37:20 PM »
Why not just do it in steel or aluminum?
oinesra
« Reply #3 on: November 10, 2009, 05:44:49 PM »
no welder.
walter
« Reply #4 on: November 10, 2009, 05:51:18 PM »
no welder.
you can do it without welder .
« Reply #5 on: November 10, 2009, 06:04:49 PM »
My time is worth more than the $16, but A+ for the effort.  :noel:
oinesra
« Reply #6 on: November 10, 2009, 09:33:01 PM »
how many of your minutes are worth 16 dollars
« Reply #7 on: November 10, 2009, 10:00:16 PM »
Less than 20  :P
« Reply #8 on: November 10, 2009, 10:06:46 PM »
oinesra
« Reply #9 on: November 10, 2009, 10:07:39 PM »
JO only? Or yes to gay stuff?
TTC
« Reply #10 on: November 10, 2009, 10:22:06 PM »
You posts instill faith in the masses.
toyolla86
« Reply #11 on: November 11, 2009, 02:16:21 AM »
i freakin love this.
hahaha. perfect for those crazy bends we always need.
twin50 son. get some
and stop acting like a muslim
« Reply #12 on: November 11, 2009, 10:19:56 PM »
Putting the real in realhomemadeturbo
TTC
« Reply #13 on: November 11, 2009, 10:21:30 PM »
Test this shit already
« Reply #14 on: November 12, 2009, 12:41:43 AM »
I think she will blow :evil:, I like :evil:
« Reply #15 on: November 12, 2009, 12:50:21 AM »
This. I wanna see if it holds up though.
« Reply #16 on: November 12, 2009, 11:47:06 AM »
Wow, you can even do reusable condom!!
Do want.
« Reply #17 on: November 13, 2009, 10:39:09 AM »
Might not be worth the time spent to the hardcore fabricators, but it's an interesting lesson in composite materials.  Next thing you know, Arsenio will be making his own 4 ply nylon reinforced silicon hoses.  Everyone starts somewhere.
Do want.
You want his used condoms??
« Reply #18 on: November 13, 2009, 10:59:54 AM »
Have you pressure tested it yet?  Does it hold up?  This interests me for strange and sharp bends needed at compressor exits sometimes.
I take back what I said about your pink IC, this makes up for it.  :noel:
« Reply #19 on: November 13, 2009, 11:28:35 AM »
Do want.
It was an impersonal use of "you" ;)
« Reply #20 on: February 02, 2010, 01:41:45 AM »
And we banned this guy?  People here are fucking stupid.
« Reply #21 on: February 02, 2010, 01:44:34 AM »
x2
