General Category => General Discussion => Topic started by: PhilStubbs on April 25, 2010, 05:07:18 PM
Title: My $300 craigs list find
Post by: PhilStubbs on April 25, 2010, 05:07:18 PM
so, i have been in need of a truck for a while now. found this super mint 1990 chevy silverado with a rod knock for $300. body is almost 100% dent free it is 100% rust free and the interior gets a 9/10 for its age. boost will be happening soon and expect a build thread when it does happen
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi571.photobucket.com%2Falbums%2Fss152%2FSecksyPeePee%2Fc7875112.jpg&hash=59fcea84e9f41cbb5f9c340e577a67b4ba2362df)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi571.photobucket.com%2Falbums%2Fss152%2FSecksyPeePee%2F2b9e02bc.jpg&hash=82217dbb6d0fb00e70677e9c6f8c0feda11c7aeb)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi571.photobucket.com%2Falbums%2Fss152%2FSecksyPeePee%2F9f86d037.jpg&hash=2c33a686fcec18ea0c485b3a79a7d9773296dcb7)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi571.photobucket.com%2Falbums%2Fss152%2FSecksyPeePee%2F15838e1f.jpg&hash=c616feea5b1cb0f51b91916bff90db2ad0c7395c)
got the engine pulled today to make room for a 350 i have been holding on to for just such an occasion
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi571.photobucket.com%2Falbums%2Fss152%2FSecksyPeePee%2F5760ab4a.jpg&hash=b46b66904c31b1b54dc9982ad1734d5720df398c)
(https://realhomemadeturbo.com/forum/proxy.php?request=http%3A%2F%2Fi571.photobucket.com%2Falbums%2Fss152%2FSecksyPeePee%2F441a2a2f.jpg&hash=3962e544fc91f99abf28002d45387e9e7fbfc5f1)
Title: Re: My $300 craigs list find
Post by: jagojon3 on April 25, 2010, 05:10:37 PM
Wow, hell of a find.
Post by: highroller54 on April 25, 2010, 05:13:17 PM
booooooooooooooo 2wdr.  >:(
Post by: PhilStubbs on April 25, 2010, 05:14:55 PM
it ran really nice too other than the rod knock. the battery was done when i went to look at the truck and we had no way to jump it off. i figured it was well worth $300 even if it didnt run at all so i bought it. got it home and put a battery in it, fired up and ran great. took a prybar to all of the steering parts and everything seems tight too. i should be able to toss this 350 in and be on the road
i really have no need for 4wd. i am in flat as hell FL. the only off roading there is to do is plowing though the mud. 4wd is just something else to break. it has a bed and can tow a trailer, thats my needs
Post by: arsenio on April 25, 2010, 06:13:45 PM
How much for the distributor?
Post by: glustic on April 25, 2010, 06:15:20 PM
Nice find sir
Post by: PhilStubbs on April 25, 2010, 06:23:01 PM
i need the distributor for the 350 thats going in
Post by: ochoa on April 25, 2010, 07:21:46 PM
damd if those tires came with it they look worth the $300 themselves
Post by: PhilStubbs on April 25, 2010, 07:30:28 PM
The tires have about 50% tread left, but the sides are chewed up by rubbing behind the fenders. The guy I bought it from cut out whatever was rubbing so I guess they are fine now.
Post by: LS1pwNzJ00 on April 25, 2010, 08:54:19 PM
watercooled manifolds good for turbo, bakalah bakalah
Post by: PhilStubbs on April 25, 2010, 08:57:05 PM
is there something i am missing about the manifolds?
Post by: jay on April 26, 2010, 09:13:02 AM
i really need to dig up a picture of those...
Post by: PhilStubbs on April 26, 2010, 11:50:09 AM
I know boats have watercooled manifolds, is that what you are talking about?
Post by: LS1pwNzJ00 on April 26, 2010, 02:08:50 PM
old lulz
Post by: crttaz on April 26, 2010, 03:38:12 PM
replace fuel pump ASAP.
Post by: 92CXyD on April 26, 2010, 05:09:37 PM
And change fuel filters as often as you can (paper elements inside them clog with just a little moisture in the fuel) :?:
Also look at the wiring to the fuel pump you will see corroded connectors and it will give you headaches if not addressed. :yes:
Also if you have a metal side saddle fuel tank check for major rust from road salt/sand trapped between the cover and the tank and replace with new plastic one. :?:
You can use the larger injectors from a 454 TB for more fuel (2x 85lbs.)  ;D
Or switch to a multiport adapters setup from Edelbrock, TurboCity or other vendors out there and just switch PROMS in your stock ecu. :yes:
Post by: PhilStubbs on April 26, 2010, 05:25:16 PM
I am considering doing a multi-port swap. The wiring should be easy since all of the GM stuff is batch fire if I remember correctly.
Still trying to decide on how I'm going to run this 350 right off the bat. The ecu has a chip for a 305 right now and I'm just trying to get it running as cheap as possible and then upgrade later. I am considering trying to tune it if possible, but I might just try to find a 350 chip. So far my research says I just need an adaptor and I can use my ostrich to tune and then burn a chip.
Post by: 92CXyD on April 26, 2010, 05:30:44 PM
Have you already checked Moates?
Post by: PhilStubbs on April 26, 2010, 07:49:56 PM
yesir. looks like all i need is this and some software
http://www.moates.net/product_info.php?cPath=64&products_id=36 (http://www.moates.net/product_info.php?cPath=64&products_id=36)
